Question How to change category icons on K1.6.x
15 years 7 months ago #90515
Replied by sozzled on topic Re: How to change category icons on K1.6.x
Let's say you want to add the three category icons to category "36" (as I described earlier in this topic). You need to create
../media/kunena/attachments/legacy/category_images/36_notlogin.gif
../media/kunena/attachments/legacy/category_images/36_on.gif
../media/kunena/attachments/legacy/category_images/36_off.gif
Do you understand?
Do you understand?
The following user(s) said Thank You: robytotem
The topic has been locked.
15 years 7 months ago - 15 years 7 months ago #90524
by applehc
Replied by applehc on topic Re: How to change category icons on K1.6.x
Yes, but my forum has 17 categories.
I created three: 67_notlogin.gif, 67_on.gif and 67_on.gif
I have inserted in .../media/kunena/attachments/legacy/category_images/67 (My first folder in Attachments)
Is correct?
I do not change anything
Is correct?
Last edit: 15 years 7 months ago by applehc.
15 years 7 months ago #90528
by applehc
15 years 7 months ago #90534
If you want to change all the category icons to the same thing, something of your own design, you need to replace the following two files:
../components/com_kunena/template/default/images/icons/folder_nonew.png
../components/com_kunena/template/default/images/icons/folder.png
If you are not using the Blue Eagle (default) template then the location will be different.
15 years 7 months ago - 15 years 7 months ago #90536
by applehc
Ahh, OK!
but folder_nonew.png and folder.png change all icons, no?
I need change 17 categories icons.
Yes, I use Blue Eagle (default) template.
15 years 7 months ago - 15 years 7 months ago #90539
Change those two files (that I mentioned in my last post) changes the icons used in every categories. If you want different icons for each category then you have to make them yourself (three files for each category). Do you understand?
Last edit: 15 years 7 months ago by sozzled.
