- Thank you received: 2
Question How to change category icons on K1.6.x
15 years 5 months ago - 15 years 5 months ago #90542
by applehc
Replied by applehc on topic Re: How to change category icons on K1.6.x
Yes, I created 3 icons for different categories. My question is where the insert icons.
with that name I have to replace folder_nonew.png and folder.png??
To complete all... I have to replace folder_nonew.png and folder.png + and create 67_notlogin.gif, 67_on.gif, 67_on.gif in ../media/kunena/attachments/legacy/category_images ?? both??
Last edit: 15 years 5 months ago by applehc.
The topic has been locked.
15 years 5 months ago #90552
Replied by sozzled on topic Re: How to change category icons on K1.6.x
If you want to change one, several, or all category icons for each of the categories then you need to create the files <cat-id>_notlogin.gif, <cat-id>_on.gif, <cat-id>_on.gif and place them in ../media/kunena/attachments/legacy/category_images
If you want to change all category icons to be the same for all categories, you need to replace the two files folder_nonew.png and folder.png in the folder ../components/com_kunena/template/default/images/icons
And that's it.
And that's it.
The following user(s) said Thank You: robytotem
15 years 5 months ago #90558
by applehc
Thank you sozzled
15 years 5 months ago #90715
by applehc
can increase the size to put a big icon?
15 years 5 months ago #91068
by Walter
Replied by Walter on topic Re: How to change category icons on K1.6.x
Hi.. I would like to add new icons ../components/com_kunena/template/default/images/icons.
How can I do?
How can I do?
15 years 5 months ago - 15 years 5 months ago #91091
Walter: As I said earlier, if we are talking about category icons, you can replace the standard category icons by replacing the two files folder_nonew.png and folder.png in the folder ../components/com_kunena/template/default/images/icons
You can add other files to this folder, if you like. How you use them, after you upload them to you site, is your business.
Last edit: 15 years 5 months ago by sozzled.
Time to create page: 0.262 seconds
