Question How to change category icons on K1.6.x
15 years 7 months ago - 15 years 7 months ago #90409 by Sphinnxx
Hi there I'm very new at using Kunena Forums,
and im trying to find a way to change the icons for the categories
Im quite new to webdesigning and i hope you can help with this question
thanks,
Sphin
Last edit: 15 years 7 months ago by sozzled. Reason: minor edit/spelling in subject
The following user(s) said Thank You: robytotem
The topic has been locked.
15 years 7 months ago - 15 years 7 months ago #90436 by sozzled
G'day, Sphinnxx, and welcome to Kunena.
Here is the answer:
Category images can be customised: you can use different images for each category. The images, however, act as a tri-state indicator that show:
  • if you are not logged-in;
  • if you are logged-in and there are unread messages in the category; or
  • if you are logged-in and there are no unread messages in the category.
This means that if you want to customise icons for each category, you need three separate images, one for each of the abovementioned states.
To illustrate this point, I've created three example images as follows:
  • filename 36_notlogin.gif (for not logged-in)
  • filename 36_on.gif (for logged-in with unread messages)
  • filename 36_off.gif (for logged-in with no unread messages)
The general approach is to create three files: <catID>_notlogin.gif, <catID>_on.gif and <catID>_off.gif (where <catID> is the forum category number) corresponding to the three states I've described.
This same approach can also be extended to sub-Categories: likewise create three images <catID>_childsmall_notlogin.gif, <catID>_childsmall_on.gif and <catID>_childsmall_off.gif. Obviously you should design these images about half the height and width as the images for the parent category.
If you are using K 1.6 these custom images need to be uploaded to the folder ../media/kunena/attachments/legacy/category_images.
The following user(s) said Thank You: robytotem, busterocaps
15 years 7 months ago - 15 years 7 months ago #90498 by applehc
Replied by applehc on topic Change the category icon
Hello.
I would like to change the icon of the overall index. Is posible?
I want to use different in each category.
Thanks.
Last edit: 15 years 7 months ago by applehc.
15 years 7 months ago #90499 by sozzled
I answered the same question yesterday. See msg #2 in this topic.
15 years 7 months ago #90502 by applehc
Ah! sorry!!
Im new and spanish person and i was lost ;)
Thank you!
15 years 7 months ago - 15 years 7 months ago #90514 by applehc
In ../media/kunena/attachments/legacy/category_images I have a numbered folders that contain pictures in forum adding pictures :S
