Question Kunena 1.6.2 and IE 8 problem
15 years 4 months ago - 15 years 4 months ago #79707 by sozzled
Perhaps "stable" isn't necessarily the most appropriate adjective. The issues in this topic relate to the use of a template that forces the Internet Explorer 8 web browser to use "compatibility mode". In other words, the site template forces a kind of "software lobotomy" on Internet Explorer.
Let us be very clear on one thing. K 1.6 is the last version of Kunena that will provide any kind of support for IE 7.
Perhaps "stable" isn't the most appropriate adjective. How about "browser-independent" or "future-proofed" instead? B)
Last edit: 15 years 4 months ago by sozzled.
15 years 4 months ago #79805 by Bakual
Removing the compatibility mode tag solved the issue and didn't raise any other problems. So I guess there was no real reason for it to be there in the first place ;)
I fully understand and agree with you in canceling the support for IE7. I'm doing the same in my own component. It's hard enough to make it work in FF, Chrome and IE8 alone :)
15 years 3 months ago - 15 years 3 months ago #82513 by AndreB
810 wrote: Hi,
you must remove:
<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7">
On your template html.
But test it,
Regards 810
Hey,
I am new to the forum, so hello to everyone.
I have the same problem as Bakual had and I hope that removing that quoted line will help. But I can't find it, I dont have a "template.html". Where is it filed?
I hope someone can help me, thanks in advance!
Andre
Last edit: 15 years 3 months ago by AndreB.
15 years 3 months ago #82517 by 810
Whats your url. Then i will check where you must edit it.
15 years 3 months ago #82518 by AndreB
810 wrote: Whats your url. Then i will check where you must edit it.
I am at an insurance company as an intern (or how do you call it, when a student works for a company for two weeks?) and improving one of their Joomla-based sites. As I am doing the development on an internal server, that is not accesible from outside the company, I cant send you a link.
I have the same problem that Bakual described, everything is fine in firefox but in IE8 the category headings are black.
We are using Joomla 1.5.22 and Kunena 1.62.
We are using a slightly modified version of the Joomla Purity template, if that might help.
When I am on the forum index page and view the HTML source code in firefox, I don't find the line that I've got to remove.
Is it in one of the HTMLs/PHPs in the kunena folder or has it its seed in the Joomla template?
15 years 3 months ago #82679 by 810
Its must be working on the joomla template. make sure that ie8 compatibility mode is disabled.
or you can check it with firebug on firefox, then you can look where he's picking the color.
regards 810
Time to create page: 0.238 seconds
