Question Kunena 1.6.2 and IE 8 problem
You can have a look at the forum here: www.sermonspeaker.net/forum.html to see what I mean.
I use the default "Blue Eagle" without any modifications yet. In Firefox it looks right but in IE the headers (Forums, Who is online, Statistics) are just black background instead of blue.
Entering colors in the template parameters does change it for Firefox, but not for IE.
It was working with Kunena 1.6.1.
Also the problem seems to be related as well to the template I use (icons-004 from www.i-cons.ch ). This is a modified Aristeer template as far as I understand it.
The default Joomla templates (Beez, Milkway) are working.
So the bug is caused by the combination of my template and the latest upgrade to Kunena.
Any hints where I could start searching?
Kunena has been tested with many different templates, using a variety of web browsers. The K 1.6 project was held up for an extra 2 months because of the special difficulties associated in untangling IE 7 issues - let's not mention the special considerations necessary for IE 8 issues! Internet Explorer is different and that's the only thing we all can happily agree upon. But the differences are not just that it doesn't behave the same way as Firefox, Google Chrome or Safari; the problems are that IE 7 doesn't behave the same way as IE 8 which doesn't behave the same way as IE9. Basically, this means that Internet Explorer puts us web designer/developers constantly behind the eight-ball.
You have my sympathy but, because I'm not an expert in catering to the vagaries of IE's CSS support, I don't have the answers for you. Perhaps someone else knows what to do?
you must remove:
But test it,
Regards 810
- snilloconator
- Premium Member
- aka snilly
Thanks a ton! That did it.810 wrote: Hi,
you must remove:On your template html.Code:<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7">
But test it,
Regards 810
It even seems to have fixed another minor issue I had with the page
I wasn't even aware that you can force the compatibilty mode in IE. Crazy stuff.
Actually I quite like this template due to the simpleness and possibility of customizing.snilloconator wrote: I would recommend a more stable free template or even the base templates that come with joomla.
I didn't find a similar free template so far
What do you mean with "more stable"? I didn't have issues so far besides this one.
