Question [Resolved] Pagination (change number of pages to display)
15 years 8 months ago #83812 by Troneas
Replied by Troneas on topic Re: Pagination
sozzled wrote:
Troneas wrote: if popular Kunena templates (such as Aphotic) and others all experience this issue, then it's pretty clear its is a kunena problem. or at the very least, its not a problem with a particular or specific template.
I don't know if we can draw the same conclusion.
There were changes made between K 1.6.1 and K 1.6.2 - these were necessary and some of them may have had unintended consequences for third-party developers. The important thing to isolate is whether you experience these issues with the Blue Eagle (default) template because this is the only template developed and supported by the Kunena project team. What is quite clear is that if you have these issues with the Blue Eagle (default) template as well as other, third party-developed, templates then the issue most likely resides with factors influenced by your site template.
If, on the other hand, you find the problems remain with these Kunena templates when you use the rhuk_milkyway template then this is something that needs to be attended to immediately. However, because we don't see evidence of these issues here at www.kunena.org , I suspect that this would not be the case (i.e. there is a fault with Kunena or with a specific Kunena template). But I could be wrong.
well lets test it then.
15 years 8 months ago #83884 by Troneas
ok it appears to work fine in blue eagle as per my pagination test .
so what now then? all templates aside from blue eagle are obsolete after 1.6.1?
15 years 8 months ago #83885 by sozzled
Replied by sozzled on topic Re: Pagination
No, that's not what I'm saying.
While we are having this discussion I am in contact with my colleagues - my fellow moderators - to see what advice we can give to you and to others in this situation.
It seems that this issue is most likely to affect those people who use very narrow site templates more than it affects other users.
These issues are not new, either: see Seitenanzahl (Pagination) sprengt das Layout in the Wiki - a topic that dates back to K 1.0.8.
As I have been trying to say, this is primarily a website issue and the solution lies in your hands. It's possible (or probable) that some Joomla site templates are unsuitable for Kunena and that's just a fact that we have to accept on faith. In your case, the component display area is 660px. Although 660px may be adequate for many Joomla components it may not always be a success with Kunena. Although not a hard-and-fast restriction, it's a good rule-of-thumb to allow 880px for Kunena. If the template is narrower than 880px then you have to make some compromises.
Does this make sense to you?
15 years 8 months ago - 15 years 8 months ago #83886 by Troneas
then why does it work fine with IE8?
Last edit: 15 years 8 months ago by Troneas.
15 years 8 months ago - 15 years 8 months ago #83888 by Troneas
hmm actually, never mind.
just learnt that IE8 also has the problem when logged in. it seems that the many buttons that appear when logged-in to moderators are pushing the page numbers overboard.
so it could very well be kunena failing to be flexible towards my 660 px.
i suggest a fix similar to the one that exists in the main board. using 1 2 3 4 ... 10 system to address this issue.
15 years 8 months ago #84523 by proterra
The following user(s) said Thank You: Troneas
