Kunena 7.0.8 Released
Merged [Merged topic] Full screen wide forum
- CheechDogg
- Premium Member
14 years 5 months ago #119628
by CheechDogg
Find me on Facebook.
Replied by CheechDogg on topic Re: Display Forum full width of screen
Remove the mod from the menu manger. You can select what menu items and pages each mod will appear on from there.
14 years 3 months ago #122904
by Tillman
Replied by Tillman on topic Unusual Behavior - Forum Size
I've read a lot of threads about the peoples forum size being off, and how to fix it etc. From what I read, it seems as if the CSS on Kunena use width: 100%; etc. So, no matter the size of the webpage, it should fit.
Well, mine fit just fine. But, I've since then tweaked some of the sizes in my templates .css file, assuming this should be okay, because what I've read/been told is that Kunena uses percentages.
All I did was change the width of my webpage from 960px to 1160px and the forums width didn't scale with that.
What can I do to fix this? I want to avoid editing the .css on Kunena, because from the way that it looks to be setup, if I simply change the value for the width of the forums to a static px width, that everything else will be out of place.
Long story short - the forums are set to scale 100% of the page, but if the page size changes after the install, it doesn't seem to respect those changes.
website - reforgedgaming.net
Thanks!
Thanks!
14 years 3 months ago - 14 years 3 months ago #122908
Replied by sozzled on topic Unusual Behavior - Forum Size
*** Topic moved ***
G'day, Tillman, and welcome to Kunena.
The problem, as I see it, is that your Joomla site template does not support collapsible module positions. Therefore you have space "reserved" on the right side of your template even though you have not assigned any modules to that position. That's something you really should discuss with the people who designed the Joomla site template that you've chosen, especially if you paid for it!
Please read My Joomla site template makes a mess of Kunena
Alternatively, you could edit the file ../templates/maxgaming-tg/css/styles.css at around line 131:
#centercontent_bg {
float: left;
margin: 0 5px;
overflow: hidden;
padding: 0;
width: auto;
#centercontent_bg {
float: left;
margin: 0 5px;
overflow: hidden;
padding: 0;
width: auto;
Last edit: 14 years 3 months ago by sozzled.
14 years 3 months ago - 14 years 3 months ago #122925
by Tillman
Thanks for the reply,
It wasn't a module position, as I was writing my last reply though, I realized something. When the forum auto added itself to my webpage, it put itself in a different DIV then the rest of my page content, I had to edit that div, hoping that it doesn't mess something else up.
Last edit: 14 years 3 months ago by Tillman.
14 years 3 months ago #122927
Replied by sozzled on topic [Merged topic] Full screen wide forum
I provided you with the answer (the CSS that you need to change in your Joomla site template file).
Time to create page: 0.536 seconds
