The Kunena team has announce the arrival of Kunena 7.1.0 [K 7.1.0] in stable which is now available for download as a native Joomla extension for J! 5.4.x/6.0.x./6.1.x./6.2.x This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 / K7.0 and issues discovered during the last development stages of K 7.1 Just a reminder: K6.4.16 receives only securities fixes until end of 2026, so it's advised for users to upgrade to K7.1.
If you have questions about third-party templates, please use the User-written Templates
category or contact the author directly. This category should only be used for questions about templates developed and supported by the Kunena project.
Question
[Merged topic] Menu tabs display vertically
The main site template is a modified version of ja_sulfur from joomlart. The kunena template is just the default blue eagle. I've copied the entire Kunena Menu into the Main Menu and just set permissions on the drop down items, which seems to be working. I've taken it offline for the moment, but if you need to have a look, let me know and I'll PM you a username and password and re-enable it.
Last edit: 16 years 3 weeks ago by saddoris. Reason: forgot something
It seems to be, yes. And to be honest, I really like the added functionality of the Kunena Menu drop down. I hope it will allow users who are looking over our site to be inspired to hit "New Topic" right from where they are and get into a discussion. That begin said, I really would like to figure out the underlying cause of the initial error.
Any suggestions, then? Shouold I dump the existing menu and build a new one? All I really want for the main menu is a rollover color and the ability to use the "Bebas" font.
