- Thank you received: 1
Kunena 6.2.4 Released
The Kunena team has announce the arrival of Kunena 6.2.4 [K 6.2.4] which is now available for download as a native Joomla extension for J! 4.3.x/4.4.x/5.0.x. This version addresses most of the issues that were discovered in K 6.1 / K 6.2 and issues discovered during the last development stages of K 6.2
Merged [Merged topic] How to add topic icons
- eigenheimer
- webdesignersuk
You can, if you really want to do this (I suppose), but what is it worth to you to do this?webdesignersuk wrote: I would also like to know if you can remove the code & the table button within the editor thanks
- dirkovision
- Senior Member
- Thank you received: 4
Hop you can give us a hint, as after the nr 9 count imge, we start at [A], like this, right: ?
$topic_emoticons [9] = 'topic-mad.png';
$topic_emoticons [A] = 'topic-burn.png';
$topic_emoticons = 'topic-spook.png';
thanks a lot for answering,
from Hungary with respect.
dirko
No, you continue using decimal numbers: 9, 10, 11 ...dirkovision wrote: ... after the nr 9 count imge, we start at [A], like this, right: ?
I need to use a specific icon for a specific topic... more o less I need 10 icons.
Is it possible?
thanks
- dirkovision
- Senior Member
../components/com_kunena/template/default
directory..
