- Thank you received: 4
Merged [Merged topic] How to add topic icons
It's called icons.php, and it's located the same place in 1.7.0dirkovision wrote: in the latest 1.6.4 release the icon.php file can be found in the:
../components/com_kunena/template/default
directory..
Indeed it is very easy to add more file names to the array and to provide more icons to the icons library.
I assume this is the reason why no option has been implemented to manipulate those icons in the Administration, like it is for the icons to be used with a forum post...
I can live with this
/Yxos, Kunena Translator, da-DK.
Overvej at abonnere på kategorien www.kunena.org/forum/48-Danish
How can I add more topic icons to the editor?
I would like to add a "Check mark" or "OK stamp" for solved / closed / replied topics.
But I got it now:
Add icons to /components/com_kunena/template/default/images/icons/
edit-add the filenames to /components/com_kunena/template/default/icons.php
ciao non trovo questa porzione di codice
thanks.
grazie.
where is this code? what is the file? this is the image for these icon
www.kunena.it/2.0/media/kunena/attachmen...y/images/avatar2.jpg
cerco ancora il codice corrispndente nel file dezippato ma non lo trovo ancora.
dove è questo codice? in quale file? questa è l'immagine di queste icone
if you see the code when open a topic you can find this code with firebug
thanks
Does this help?
