Question Tabs with Kunena menu ok only if default
15 years 5 days ago #108211 by nolie
Thank you.
I'm using joomla 1.7 and kunena 1.7
A new install today and my main menu title shows "menu", alias says "2011-09-30-14-46-39", and the link is "index.php?Itemid=180", and it says menu type is a "menu item alias".
Kunena menu says tilte is "forum, alias is "forum", link is "index.php?option=com_kunena&view=entrypage&defaultmenu=182", and menu item type is "entry page".
How should things be set to work like kunena.com forum?
Thanks again.
15 years 4 days ago #108248 by nolie
Does anyone have any input on this?
See how my item ids are different for both menus.
Also, these item ids don't respond to module positions unless they're specifically set for kunena menu items.
Thanks for any help.
14 years 11 months ago #108902 by patrYce
Hello everybody
great forum, thank developpers !!!
but with joomla 1.6 and kunena 1.7
a bit like nolie :
The tabs on the forum does not appear, it is not practical to see that makes it unusable.
link "Forum" in joomla = index.php?option=com_kunena&view=entrypage
Kunena testing with ie 9, firefox7 / 8 chrome, safari dont work...
Thank you and good luck
14 years 11 months ago #108998 by patrYce
:blush:
It's good !!!! :)
I' am french (sarkozyste, that's why ...), sorry and well I started with joomla.
DOC : The Kunena menu is a set of tabs that appears across the top of the forum pages. In some cases, this menu does not appear for a variety of causes.
A simple remedy for the problem is to use the trash-burn-build technique:
1. Trash all existing menus and menu items that relate to your Kunena forum
2. Ensure that you do not have a folder named /forum on your site.
3. Empty the menu trash.
4. Use the Create Menu feature in the Kunena control panel to restore your Kunena menu.
5. Make sure that you publish a link in your menu that calls the Kunena forum. Use the Alias Menu type to define that link (see Customised menus for more information)
6. Ensure that you have published a menu module for the kunenamenu template position.
In French :
j'ai supprimé tous les menus forum, liens forum du site (module et menus)...
j'ai vidé ma poubelle (3)
j'ai recrée menu kunena
j'ai été dans le menu du top pour le lien "forum" voir pièce jointe du dernier post :
Type d'élément de menu :j'ai "changer le type" par alias (le dernier tout en bas)
Dans paramètres menu, Élément de menu : j'ai choisi "menu kunena" ->index
Jai sauvé et bingo, cela marche parfaitement !!!!
Excusez ma bétise !
Super forum, bravo et merci !
In poor English :
I removed all menus forum, forum links on the site (module and menus) ...
I emptied my trash (3)
I recreated menu Kunena
I was in the top menu for the link "forum" see attached the latest post:
Type menu item: I "change the type of" Alias ​​(the last at the bottom)
In Settings menu (at right), menu item: I chose 'Kunena menu "-> index
I saved and bingo, it works perfectly!!
Excuse my stupidity!
Great forum kunena, congratulations (champagne !) and thank you!
Time to create page: 0.235 seconds
