Question Tabs with Kunena menu ok only if default
15 years 2 months ago - 15 years 2 months ago #107919 by io2000
I searched the forum but have not found the answer. If I set the Kunena menu as default, tabs are displayed correctly. See picture below 1. But if Kunena is not default menu, tabs no longer appear. I tried and different templates. The problem persists. I need help because i don't want kunena to be my first page. If I set kunena as default menu my index is the forum and it's not ok. Thank you.
Last edit: 15 years 2 months ago by io2000.
15 years 2 months ago #108112 by io2000
No solution?
15 years 2 months ago #108113 by xillibit
What do you mean by Kunena is the default menu ?
15 years 2 months ago #108122 by io2000
In joomla> Menus default must be Kunena Menu and not Main Menu. Please see the attach.
If I set Kunena Menu as default my first page of site show the forum. If I set Main Menu as default my first page is the site but in forum tabs no longer appear.
15 years 2 months ago #108150 by nolie
I am having the same misunderstanding with my menu installation.
In this forum, for example, if I click the main top menu item "forum", the forum tab lights blue and indicates the right itemid. Then if while I'm here at this forum and click "search" in the kunena menu, both search in the kunena menu and forum in the main menu are lighted to indicate the same itemid.
How is this installed to work this way?
In my installation, the default install names the kunena menu alias "forum". But then when I want to name my main menu forum link alias "forum", it won't allow it because a top kunena menu item already has that alias.
O.K., so I name kunena alias "forum" and main menu alias "forums". When I hover over main menu link, the url says "forums.html" but it actually goes to "forum.html". And then every link in the forum is based on "forum". However, the itemid is not correct and menu modules do not respond to main menu.
The question is simply, how are menu items correctly configured so that both menus that go to the same place work together?
Thanks for any help on this.
15 years 2 months ago #108158 by xillibit
Can-you put here please your Kunena report configuration settings ?
