Question 10 to 20 second delay on post submit
I also checked jos_kunena_config_backup and it was also pollenabled = 0
With pollenabled = "0" and the delay still occurring should I assume that my hosting environment is simply incompatible with Kunena? Or are you confident that this issue can be resolved at some point?
Generally Kunena was running very fast in your server and sending a message is just like loading a large category page -- just with INSERT INTO queries instead of SELECT queries. It should be about as fast.
This is not a poll issue; I believe that the poll issue is IE9 incompatibility with our JavaScript.
The only thing that get slow is sending all the emails to subscribers. You can ensure that no emails is being sent by leaving email address in Kunena configuration empty. But I doupt that this is the case.
I believe that you have something wrong in the server configuration itself as no PHP page should kill your site. It almost looks like some processes in the server become zombies or die, and that's usually because of a bug in that software or a bad mistake in PHP/Apache/MySQL configuration.
Check in source code of the page if you have numerous javascript loaded
