Question 10 to 20 second delay on post submit
15 years 5 months ago #97291 by bobede
I've been searching through this forum and trying everything I can to try and solve this issue. When you create a new topic or reply to an existing topic and click the submit button, there is a 10 - 20 second delay before the screen refreshes. This leads to posters clicking the submit button repeatedly because they think the post wasn't sent.
I read that it could be template related, so I tried with the default beez2 template and get the same results.
I tried turning subscriptions off completely - still get the delay.
I tried changing the SMTP server to one that I know is functioning perfectly for other sites - still get the delay.
I then tried PHP mail function - same thing.
I thought it might be SEO related, so I tried turning off those options in Joomla - guess what? I still get the delay.
I initially had uddeIM installed. Uninstalled it and made sure that under integration the option is set to "none". Still get a delay.
I'm including my configuration report below. One thing that I don't get is that when I expand the section for Kunena menu, it doesn't show any of the items. I recreated the menu following instructions I found here and it remains the same.
Hopefully, there is something glaring in this report that explains the delay.
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 64M | Max file upload: 50M
Joomla default template details : wd16 | author: Bob Wilson | version: 1.0 | creationdate: 03/03/2011
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Search 1.6.4
Modules: Kunena Search 1.6.4
15 years 5 months ago #97292 by bobede
I just posted this on your site and there was a delay of over 10 seconds. Could this be browser related?
15 years 5 months ago - 15 years 5 months ago #97302 by Mortti
bobede wrote: I just posted this on your site and there was a delay of over 10 seconds. Could this be browser related?
I think it's your connection problem (or there is something program on what take all bandwidth). Try reboot your computer at first.
Last edit: 15 years 5 months ago by Mortti.
15 years 5 months ago - 15 years 5 months ago #97329 by sozzled
We are not really able to help very easily in this case because we don't know where the problem occurs. Because the problem is not widespread it is unlikely that the issue is related to Kunena but possibly due to an almost infinite range of possibilities. The only information that I can suggest, at this time (and in the absence of full disclosure of information in the K 1.6 configuration report posted here) is to read K 1.6 Technical Requirements.
I do not doubt that there is a problem on the user's website but I do not know what specific information bobede expects from us, either.
FYI, I live 7,500 km (as the crow flies) from the server where www.kunena.com and the round-trip from when I press the submit button to receiving a response is about 2 seconds.
Last edit: 15 years 5 months ago by sozzled.
15 years 5 months ago #97533 by bobede
sozzled wrote: (and in the absence of full disclosure of information in the K 1.6 configuration report posted here) is to read K 1.6 Technical Requirements.
The only thing I changed in the report that Kunena created was the domain url and the mail server. It is a private site, and I can't really share that information with the rest of the planet.
As for your referral to the Technical Requirements, the documentation clearly states that during installation Kunena checks to ensure that all technical requirements are met and that in the event they are not met, the software does not install and returns an error message. So unless that's a boldface lie, I wouldn't have been able to install Kunena if the server didn't meet the requirements. Regardless, everything listed in the technical requirements is included in the report.
15 years 5 months ago #97538 by sozzled
You do not have to share the information with the rest of the planet. If you don't want to share that information with administrators/forum moderators of this site, that is also your decision and we respect that.
There are parts of the K 1.6 configuration report that are only viewable by administrators/forum administrators. The development team understands this need for privacy and that is why the K 1.6 configuration report was constructed the way that it was. If you doubt this, look at any other topic on this site, where people have posted their configuration report, and you will not see that information, either ... but we can even if you can't.
You want us to check the latency on your site? How would you like us to do that?
The Kunena installation procedure checks most of the common problems that may occur but it's not foolproof. Some things are not easy to check and that's why the K 1.6 Technical Requirements document was written. But even there, this document is only meant to be a guide and I think it's unfair to conclude that it provides comprehensive coverage of every difficulty that users may experience in "the real world". The responsibility for verifying that you have a reliable basis to install Kunena is up to you. For those who would rather not take on this technical burden themselves, they can always call in (and pay for) expert specialist assistance.
Time to create page: 0.150 seconds
