Question Call to undefined method JController::getInstance() in \...\components\com_users\users..php
When I look at some public topic in Kunena (as not logged in user), and I click on users name to see his details, I must normally log in, but then I get this error:
Fatal error: Call to undefined method JController::getInstance() in \...\components\com_users\users.php on line 17
Line 17:
$controller = JController::getInstance('Users');
What can I do? Thanks.
This message contains confidential informationhtaccess: Missing | PHP environment: Max execution time: 600 seconds | Max execution memory: 128M | Max file upload: 50M
Joomla default template details : ja_purity | author: JoomlArt.com | version: 1.2.0 | creationdate: 12/26/07
board_title --- board_offline 0 board_ofset 0.00 offline_message <h2>---</h2>
<div>...</div>enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 15 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 0 template default showannouncement 1 avataroncat 1 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 0 allowfavorites 1 maxsubject 50 maxsig 300 regonly 0 changename 0 pubwrite 1 floodprotection 10 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 avatarquality 85 avatarsize 200 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 1000 allowfileupload 0 allowfileregupload 1 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2,doc,docx,ppt,pptx,xls,xlsx filesize 1000 showranking 1 rankimages 1 avatar_src fb fb_profile fb pm_component no userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory 0 showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 rules_infb 1 rules_cid 1 help_infb 1 help_cid 0 showspoilertag 1 showvideotag 1 showebaytag 1 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage recent default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 0 sefutf8 1 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 0 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:00:01 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access auto integration_login auto integration_avatar auto integration_profile auto integration_private uddeim integration_activity auto boxghostmessage 0 userdeletetmessage 1 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 activity_limit 0 show_list_time 720 show_session_type 0 show_session_starttime 0 userlist_allowed 0 userlist_count_users 1 enable_threaded_layouts 0 category_subscriptions post topic_subscriptions every pubprofile 0
Third-party components: UddeIm 2.2
Plugins: System - Mootools Upgrade: Enabled | System - Mootools12: Disabled | Kunena Search 1.6.2
Modules: Kunena Latest 1.6.2
These are your problems:
(1) You are using legacy mode. 75% of the people who ask for our help do not need legacy mode. If you don't need legacy mode, don't use legacy mode. Please read the important information about using legacy mode.
(2) You have set Forum Configuration » Integration » Integration Options » Activity Notifications = Auto detect
You don't need this. Set it to None. Even better, set all Kunena config options back to their default values. Make sure that Kunena works with default values before you change things, and check what happens when you change things.
(3) If you want to use the Kunena Search plugin and the Kunena Latest module, please upgrade to the latest version. The versions that you are using are not compatible with K 1.6.4. If you don't use or need these things, then uninistall them.
(4) You may want to look into using Joomla SEO - see Search Engine Optimisation (SEO) in the Wiki. This isn't related to your current problem, it's just a suggestion.
It is possible that, even if you fix the things I've mentioned above, you may have not properly installed K 1.6.4 correctly. If necessary you may need to re-install K 1.6.4. Please read K 1.6 Upgrade Guide .
Next time you have a problem, please post your updated and unedited K 1.6 configuration report for a faster response. Thank you.
