Question Class 'JAccess' not found - but running J 1.5.22
15 years 4 months ago - 15 years 4 months ago #79368 by xillibit
In Kunena configuration panel, in the tab Integration, what do you have for Access Control ?
This error is displayed when you see which page in kunena (view a message, post/reply to a topic, view a profile...) ?
Last edit: 15 years 4 months ago by xillibit.
15 years 4 months ago #79432 by sozzled
... and it would also help if you upgraded to K 1.6.2, too! ;)
15 years 4 months ago - 15 years 4 months ago #79441 by Pat.Ryan
Upgraded to 1.6.2 same result.
In Control panel Access choices are Auto Detect / Community Builder / Joomla. Same result with any choice.
Legacy mode on of off, same result.
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 90M | Max file upload: 7M
Joomla default template details : rt_solarsentinel_j15 | author: RocketTheme, LLC | version: 1.5.9 | creationdate: August 19, 2010
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.6.2 | creationdate: 2010-12-29
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.3.1) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
Modules: Kunena Latest: Enabled (Version : 1.6.2) | Kunena Stats: Enabled (Version : 1.6.2) | Kunena Login: Enabled (Version : 1.6.2)
Last edit: 15 years 4 months ago by Pat.Ryan.
15 years 4 months ago #79443 by Pat.Ryan
xillibit wrote: In Kunena configuration panel, in the tab Integration, what do you have for Access Control ?
I never get to any Kunena page. I get this from a menu choice. The menu choice is a Kunena forum Entry Page. The same thing happens with any Kunena menu choice.
15 years 4 months ago #79444 by sozzled
Why are you still using Legacy mode ... after your claim that you disabled it? Please read the very important information about Legacy mode and remove your dependence on this "feature". I know this is not what's causing the problem but it can't hurt to be on the safe side, can it? ;)
15 years 4 months ago #79464 by Pat.Ryan
I have Legacy mode enabled because I still have a few components that require it. I am working on replacing them but that is not complete yet.
I see in administrator/components/com_kunena/libraries/integration/access.php and in integration.php that the test for the Joomla version is based upon the presence of JPATH_LIBRARIES.'/joomla/access'. While I don't have J1.6 running, I do have this directory on my system. Is this not part of the basic J1.5?
Time to create page: 0.304 seconds
