Question Class 'JAccess' not found - but running J 1.5.22
15 years 4 months ago #79465 by Pat.Ryan
So I'm not sure just where the /access directory came from. It is clearly part of the J1.6 directory structure but not the J1.5. I renamed it to something else. Kunena now works and so far I haven't found anything else broken.
With fingers crossed we'll start using Kunena 1.6.
15 years 4 months ago #79472 by xillibit
Yes, the access directory PATH_LIBRARIES.'/joomla/ is normally present on Joomla! 1.6 i don't know how it's possible that you have this directory under Joomla! 1.5, so we need to change this check in integration.php to be more more reliable.
15 years 3 months ago #83804 by suptm01
Replied by suptm01 on topic getting fatal message
Please help, I am getting the below message after installation.
Fatal error: Class 'JAccess' not found in /home/fhlinux010/b/bolton-unitarians.org.uk/user/htdocs/joomla/administrator/components/com_kunena/libraries/integration/joomla16/access.php on line 113
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 20M | Max file upload: 20M
Joomla default template details : ja_purity | author: JoomlArt.com | version: 1.2.0 | creationdate: 12/26/07
Kunena default template details : Example Template | author: Kunena Team | version: 1.6.2 | creationdate: 2010-12-29
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.3.1) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.2)
15 years 1 month ago #90413 by Endoc1
I, too, get this error. I happened after a failed attempt to upgrade to Joomla 1.6. I have since reverted back to 1.5.22, but still have the error. Can you please post some detail on what to change so this can be resolved? Your help would be greatly appreciated.
Thanks,
Jon
15 years 1 month ago #90418 by xillibit
Please use k1.6.3 which fix the issue
15 years 1 month ago #90453 by Endoc1
Thanks for the response. I upgraded to 1.6.3 successfully. The original error no longer occurs, but the forum will not either. Now I get the following error in Internet Explorer (see attachedimage).
Any other ideas?
Thank you-
Jon
Time to create page: 0.271 seconds
