Question Class 'JAccess' not found - but running J 1.5.22
15 years 5 months ago #71834 by Pat.Ryan
I just upgraded to K 1.6.1 today from 1.5.13 and get the following error. Running Joomla 1.5.22
Fatal error: Class 'JAccess' not found in /home/xxxxxx/xxxxxx.xxx/public_html/joomla/administrator/components/com_kunena/libraries/integration/joomla16/access.php on line 113
I saw that this same issue was reported in the Test category about a month ago. Any solution for this yet? Do you still want to see my site?
Here are the report configuration settings:
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Enabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 90M | Max file upload: 7M
Joomla default template details : rt_solarsentinel_j15 | author: RocketTheme, LLC | version: 1.5.5 | creationdate: March 25, 2010
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.2.2) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
15 years 5 months ago #71836 by 810
Hello try to update cb to 1.2.3 , this will fixed it
regards 810
15 years 5 months ago #71840 by Pat.Ryan
Thanks for the suggestion. No luck. I upgraded CB to 1.2.3. Completely uninstalled Kunena (including deleting the tables in the database). Reinstalled K 1.6.1. Same error.
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.2.3) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
15 years 4 months ago - 15 years 4 months ago #78587 by Pat.Ryan
Anyone have any ideas? Developers is this on the to-do list?
Now running CB 1.3.1 with same result. So not likely CB issue.
Last edit: 15 years 4 months ago by Pat.Ryan.
15 years 4 months ago #78623 by xillibit
Please disable legacy mode and check what's happen
15 years 4 months ago #78645 by Pat.Ryan
Legacy mode makes no difference. I still get
Fatal Error: Class 'JAccess' not found in administrator/components/com_kunena/libraries/integration/joomla16/access.php on line 113
Time to create page: 0.290 seconds
