Kunena 7.0.8 Released
Question Profiles not saving (avatars not uploading)
15 years 10 months ago #68594 by Sanyi
Thank you Sir! B)
It works perfectly. Many thanks for your quick help. ;)
You wrote also that it is highly recommended to turn off "Legacy Mode" and eliminate extensions that were developed for Joomla!1 and thus work just in "Legacy Mode".
I would do it, but I have a lot of extensions installed and I can't remember which of these need Legacy Mode ... :(:sick: Is there a simple way to ascertain/find out which of these extensions have to be removed? (I don't want to use "Trial and Error Method")
Thanks for your help again.
Best regards,
Sanyi
15 years 10 months ago #68595 by Hurr1c4n3
Go to the backend of Joomla.
Extensions > Install/Uninstall
The click on the different categories (Components, modules ....) and see if the compatibility is a cross or a green mark.
Green is good, red is bad :-)
The following user(s) said Thank You: Sanyi
15 years 6 months ago #88569 by deemo
Hi Guys
I have been having the same problem with users not being able to update their profiles add avatars or anything even though they report as saved or uploaded.
I'm using 1.6 Joomla and 1.6 Kuena.
I have discovered that Kuena profiles are not being correctly created on the bank end unless, I use the synchronize user tool and selcting clear user cache (option 1) and add user profiles to everyone (option 2) once i do this the users can update their profile.
I then tested wether users would be able to update their profile after they had made their first post without me running user synch and they can not.
I also tested if the super admin browsing a new profile via the frontend using the latest user link in the statistics are would do what ever needed to be done to make the profile editable and it does.
So it seems to me tht my users are not being automatically brought across from joomla registration to Kuena user list.
My settings are below.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 48M | Max file upload: 4M
Joomla default template details : 1 | author: DeeMo Design | version: 1.0 | creationdate: 2011-03-01
Can anyone offer a solution or is there a plugin that will allow me to schedule an hourly user synch?
15 years 6 months ago #88572 by 810
just wait for 1.6.4, then its working again, it will be released soon +- week.
regards 810
15 years 6 months ago #88573 by deemo
810 wrote: just wait for 1.6.4, then its working again, it will be released soon +- week.
regards 810
Sorry looking through the thread I wasn't sure anyone had pinned down that it was profile synch that was causing the issue
15 years 5 months ago #89829 by deemo
regards 810
Any idea how that's coming as current version seems to have many bugs
