Kunena 7.0.8 Released
Question Profiles not saving (avatars not uploading)
15 years 10 months ago #65348 by JugglesXP
I had no problems actually installing, although I was using the DEV build, not the regular public release.
I have confirmed the problem also exists on Chrome 8.0.550.0 canary build
I switched joomla SEO off as well, it had not effect.
15 years 10 months ago - 15 years 10 months ago #65359 by motd1024
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 50M
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.2.3) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
Hi
Same issue here. using Firefox 3.6.10.
I want to uninstall Community Builder, only this problem prevents me to do it.
I have to use CB avatars until this is fixed.
Enabled the mootools upgrade plugin, but with the same result.
Edit: Tested with Internet Explorer 8, profile update and avatar upload works.
Last edit: 15 years 10 months ago by motd1024. Reason: More info
15 years 10 months ago - 15 years 10 months ago #65362 by JugglesXP
I can also confirm a redirect error in the latest joomla. I have a few components that are NOT playing nicely with joomla's SEF's
this seems to ONLY be effecting images at the moment however, at least on my machine. components/com_kunena/template/default/images/english/ranks/rankadmin.gif Note the English, after the images folder.
Last edit: 15 years 10 months ago by JugglesXP. Reason: added new info
15 years 10 months ago #65478 by sozzled
JugglesXP wrote: I can also confirm a redirect error in the latest joomla. I have a few components that are NOT playing nicely with joomla's SEF's
Can you please explain, in what ways, specifically, do either of these things have any impact on the discussion topic "profiles not saving (avatars not uploading)"?
15 years 10 months ago #68227 by Greight
H also have the same problem. Isn't going to be a solution here?
15 years 10 months ago #68228 by xillibit
Are-you using Google Chrome ?
Time to create page: 0.293 seconds
