Kunena 7.0.8 Released
Question Profiles not saving (avatars not uploading)
15 years 10 months ago #68240 by Greight
Replied by Greight on topic Worked!
Thank you. It worked perfectly! This was an instance of great support.
15 years 10 months ago #68338 by PugDaddy
Using Firefox 3.6.12 I couldn't upload an avatar, but I could upload the avatar using IE8. So after searching the forums and net and trying the suggestions, I couldn't repair the problem until I used the file you provided. Works better than new now! :-)
I just wanted to say thank you for the fix and verify it works with Firefox 3.6.12 also.
15 years 10 months ago #68350 by motd1024
Your fix is working. Thank you.
Firefox 3.6.12 confirmed.
15 years 10 months ago - 15 years 10 months ago #68367 by WooF
Hm did't work for me. User porofiles are ok but avatars not working. Any idea. I have set the forum ok so that is not a problem.
Last edit: 15 years 10 months ago by WooF.
15 years 10 months ago #68494 by Sanyi
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 40M
Hi Guys,
I have the same problem: User Profile cannot be edited ... or better to say changes cannot be saved.
I use Joomla 1.5.21 (upgraded form 1.5.18), Kunena 1.6 and Google Chrome
How to use this profile_2010-10-31.zip containing profile.php? What to do? I can't install it, because it doesn't contain XML file.
Do I have to unzip and copy to my site? In which folder?
Many thanks in advance,
Sanyi
15 years 10 months ago #68506 by sozzled
G'day, Sanyi, and welcome to Kunena.
Thank you for posting your configuration report. I notice that your configuration report shows that you are running J! 1.5.21 in Legacy mode. Please read the important information about Legacy mode and take action now, before you run into problems in the future.
Extract the file and replace ..components/com_kunena/funcs/profile.php on your website.
The following user(s) said Thank You: Sanyi
Time to create page: 0.423 seconds
