Question yet another menu problem :)
16 years 3 months ago #57476 by David_Steadson
Much appreciated! let me know what you need.
16 years 3 months ago - 16 years 3 months ago #57477 by Cerberus
tempory ftp access to teh actual files so i can try and work out were its loading teh submenu code from, i would expect if you insert it into teh header.php fiel it should load on every page :)
or you can just try and find what file this is located in " <div class="clearfix" id="ja-subnav"> " and move that whole div statement ( div will end in </div> ) to the header.php file yourself
Last edit: 16 years 3 months ago by Cerberus.
16 years 3 months ago #57478 by David_Steadson
It looks like a simple, quick solution for me will be to hack the kunena code to have a fixed itemid. That should be a relatively minor change.
16 years 3 months ago - 16 years 3 months ago #57479 by David_Steadson
Cerberus wrote: tempory ftp access to teh actual files so i can try and work out were its loading teh submenu code from, i would expect if you insert it into teh header.php fiel it should load on every page :)
menus files are loaded from template subdirectory. here's a zipped copy (ETA: I'm using splitmenu)
I'll check that out too
Last edit: 16 years 3 months ago by David_Steadson.
16 years 3 months ago #57482 by David_Steadson
David_Steadson wrote: It looks like a simple, quick solution for me will be to hack the kunena code to have a fixed itemid. That should be a relatively minor change.
hmmm ... or even better perhaps with mod_rewrite to make it upgrade proof ....
16 years 3 months ago - 16 years 3 months ago #57486 by Cerberus
so you are using a module for your menus then (splitmenu) = a module
clearly this is not a support question or a bug error in kunena but a template issue can one of the mods please move to relervent cat please :)
