Question yet another menu problem :)
16 years 3 months ago - 16 years 3 months ago #57463 by David_Steadson
The site I'm dveloping, and forums, are available in 2 languages. I use joomfish to change menulinks to direct people to the correct kunena section for their language. I also provide to submenu links to these sections.
The problem is that the new "kunena menu" section is screwing up all my formatting. Once you click on anything in Kunena it's taking itemids from kunenamenu, making my top menu highlight tab and submenu disappear. You can see what I mean here -
www.fittogether.se/index.php?option=com_...&catid=12&Itemid=146
Any suggestions on how to get around this? I want the top (orange) menu and submenu to remain showing when navigating within Kunena.
htaccess: Missing | PHP environment: Max execution time: 300 seconds | Max execution memory: 128M | Max file upload: 30M
Kunena version detailled: Installed version: 1.6.0-RC1 | Build: 3173 | Version name: Kujadili | Kunena detailled configuration:
Last edit: 16 years 3 months ago by David_Steadson. Reason: fix link
16 years 3 months ago #57466 by Cerberus
is you orange menu a module in it own right if it is , have you set it to be published in all of teh kunena menu items ???
16 years 3 months ago #57470 by David_Steadson
the menu is built in to the template, joomlart's Sanidine II
16 years 3 months ago #57472 by Cerberus
then you will need to speak to them and see if they can help, but i suspect that it is a module and all you have to do is publish it to all teh kunena pages.
16 years 3 months ago #57474 by David_Steadson
It's not a module, it's settings are set in the template parameters. It worked fine with Kunena 1.5, 1.6 breaks this through using a joomla-based menu system that conflicts with any existing menu system. A nice idea in theory I guess, but breaks templates like mine :(
joomlart support is pretty much non-existent, so guess I'll just have to see if I can come up with some other solution. :(
16 years 3 months ago - 16 years 3 months ago #57475 by Cerberus
give me a few hours and will see what i can do for ya.
edit: i have looked at the code for your template and it should be possible to do what you want and when i manual move the code to the other pages (firebug) it works as expected :)
but without be able to look at the actual files i cant tell you exactly what code you will need to change.
Last edit: 16 years 3 months ago by Cerberus.
Time to create page: 0.146 seconds
