- Thank you received: 9
Kunena 7.0.8 Released
Question J! 1.6 + K 1.6 Upgrade error: unable to write entry
Topic split from upgrade error: unable to write entry
similar problem for me on J! 1.6. First I get a "Database row is empty" then it lets me do the install. Goes all the way through until the end where I get "Uncaught Exception: Another menu item has the same alias in Root. Root is the top level parent"
I've gone through all of my menus including the menu trash. There is nothing using "forum" or even close. I uninstalled Kunena several times. I went into the DB directly to make sure there was nothing. Went through my web root and cleaned out all references to Kunena. the last one hiding was under /Media/
Have done this several times trying everything. Can't get past this.
There have been a number of reports about issues with installing or using K 1.6 in Joomla 1.6. Some of these issues are show-stoppers if users are considering Joomla 1.6 to run their production websites. Many of these issues will be fixed in future releases of Kunena and Joomla. For the time being, we are asking users to continue to use the K 1.6 test reports category to report issues that that they have with K 1.6 and J! 1.6.
- Thank you received: 2537
you had created another menu (in main menu?) with the same "alias". Go in "backend > menus". Delete all Kunena menus and also the link from the main menu to the forum.
After you must go to "database > jos_menu" and delete also all entrys from another menus to the forum.
Afterwards works the upgrade.
And please, to give new menus not the same alias name such as "index or recent topic"
Préparation de l'installation ... OK
Create kunena_version ... OK
Installation du plugin System - Kunena ... OK
Create kunena_announcement ... OK
Create kunena_attachments ... OK
Create kunena_categories ... OK
Create kunena_config ... OK
Create kunena_favorites ... OK
Create kunena_groups ... OK
Create kunena_messages ... OK
Create kunena_messages_text ... OK
Create kunena_moderation ... OK
Create kunena_polls ... OK
Create kunena_polls_options ... OK
Create kunena_polls_users ... OK
Create kunena_ranks ... OK
Create kunena_sessions ... OK
Create kunena_smileys ... OK
Create kunena_subscriptions ... OK
Create kunena_subscriptions_categories ... OK
Create kunena_thankyou ... OK
Create kunena_users ... OK
Create kunena_users_banned ... OK
Create kunena_whoisonline ... OK
Installation des données exemples ... OK
... FAILED Uncaught Exception: Un autre élément de menu possède le même alias dans la racine. La racine est le parent de plus haut niveau.
What's wrong?
rich wrote: Hello xreliable,
Joomla!16. has a trash menu?I even emptied the menu trash.
You have this report:
You can delete in the backend all menus, but in the database jos_menu remains a rest. You must find this entry....FAILED Uncaught Exception: Another menu item has the same alias in Root. Root is the top level parent
