Question [SOLVED] Default Template Not Loading - [Disable RokGZipper Plugin]
15 years 5 months ago #98928 by trechriron
I noticed that the configuration record is not saving to the database. Is this the problem?
15 years 5 months ago #98929 by trechriron
SOLVED!! :woohoo:
The record does save to the database when you save it the first time.
I had to disable System - RokGZipper plugin. Once that was done, everything loaded like a champ.
Wow, how annoying.
So. Where ARE all the Kunena developers/admins/experts anyways? :side:
15 years 5 months ago #98931 by sozzled
trechriron wrote: I had to disable System - RokGZipper plugin. Once that was done, everything loaded like a champ.
Yes, that's the one!
trechriron wrote: So. Where ARE all the Kunena developers/admins/experts anyways?
Asleep, probably. To be honest, the development team are fully occupied at the moment dealing with J! 1.7 and K 2.0 issues. That's not to say that no-one has an interest in J! 1.5.x and Mootools-related issues like you discovered, but that's just the way things go sometimes. Life, eh? What a pity when it gets in the way of solving other people's problems.
Thanks for letting the community know what caused your problem (and for showing what caused it in the changed subject). I'm sure your hard work will help others.
14 years 8 months ago #121100 by Evopro
Hi
I just wanted to let all know that run Rocket Theme templates (Gantry) and who sees problems with their Kunena templates.
Unpublish the System - RokGZipper Joomla Plugin and see if this helps. I have encountered this problem on a few sites now and unpublishing this plugin always fixed the problem.
Best Regards
Johan Niklasson
