Question [SOLVED] Default Template Not Loading - [Disable RokGZipper Plugin]
15 years 3 months ago - 15 years 3 months ago #98505 by trechriron
I upgrade the forums on a website I'm working on from 1.5.x to 1.6.4. The upgrade worked great, I migrated the data first, then selected finish.
I found a template to use; pizcar.in/joomla/kunena/56-argentrc-dark-kunena-template
I used the template manager to install the template.
I then set it to default.
I refreshed the expired cache, refreshed my browser cache, and clicked the link. The template is acting like the old "custom" template from 1.5.x. It won't load the default template.
I changed the template to the default Blue Eagle, and it still looks terrible.
How do I get the new template to take affect and ditch the old settings? Or refresh? Please help, it worked on my local test site using XAMPP on localhost, but not on my provider. :-(
Site URL: (this is a temp url) - 184.154.229.15/~btrc4757/index.php/forum
My Configuration Settings;
htaccess: Missing | PHP environment: Max execution time: 45 seconds | Max execution memory: 96M | Max file upload: 24M
Joomla default template details : rt_dominion_j15 | author: RocketTheme | version: 1.5.11 | creationdate: December 8, 2010
Kunena default template details : ArgentRC Dark | author: Gonzaunit | version: 1.6.0 | creationdate: 2010-08-20
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Search 1.6.4
Last edit: 15 years 3 months ago by trechriron.
15 years 3 months ago #98667 by trechriron
Good morning (from Sunny Henderson NV)! :D
Anyone else having trouble with getting templates to work/refresh?
Any ideas what I can do to fix it?
15 years 3 months ago #98801 by Matias
Above template is too old and it doesn't work anymore because of some security fixes in Kunena 1.6.2. Just try to find new template that has been tested in latest versions.
15 years 3 months ago #98892 by trechriron
I uploaded several and tried to load them. It doesn't change anything. It looks the same.
What am I missing?
15 years 3 months ago #98900 by trechriron
I tried enabling the mootools upgrade. That didn't impact anything, and it breaks the Rocket Theme template.
I have uploaded several templates, and the look is generally the same. On my sandbox, the templates appear as they do in the pictures, but on the production site, they all look basically the same.
15 years 3 months ago #98927 by trechriron
I have uninstalled, removed all files, and installed fresh.
The template looks NOTHING like the previews. It's somehow blending with the Rocket Theme template even though that option is not enabled.
Please Help!!!
Time to create page: 0.268 seconds
