- Thank you received: 4
Question URL Issue
godweb wrote: My old url was like www.blabla.com/forum-bla/name-category/id-titlepost.html
New url are like www.blabla.com/component/kunena/name-category/id-titlepost.html
The same for me.
I updated my kunena from 1.6 to 1.6.1 (Joomla 1.5.22)
I i have no sef-extensions, and i use only the default Joomla-Sef. :huh:
Here is what you need to do if you want to use native Joomla SEO: read the guide given in Search Engine Optimization (SEO) in the Wiki.
sozzled wrote: I don't use any third-party SEF "optimisation" products either. From all the horror stories I've read on the subject, these third-party products cause more problems than they're worth. As your forum grows, the search-engine friendliness becomes choked by the loss of performance.
I don't think this is the place to discuss the best SEO's strategies. Your response can be misleading
In fact, by setting ARTIOSef (extension) in "default Joomla! Router" is like don't have any third-party SEF "optimization" products (at least in the forum). And even completely disabling ARTIOSef in all website the problem remains the same.
@godweb Please reinstall JoomSEF and clear all the SEFed URLs and the cache. I just know this way to do it without querying the db manually but maybe xilli or any other developer know a better way. Then clear also the browser cache.
If the extension for ARTIOSef is set to "default Joomla! Routers" there isn't any SEF URL generated by ArtioSef for Kunena
In theory, the problem should be resolved as in this discussion www.kunena.org/forum/172-k-16-installati...nged-after-upgrading , but also by doing so I can not reach any solution.
Any suggestions?
I also do not use any third-party SEF.sozzled wrote: I don't use any third-party SEF "optimisation" products either.
Edit:
Okay, i think the problem is the menu.
Do not delete the menu "kunenamenu" and make your own menu. :pinch:
I have tryed everything. When I delete categories its allright but that is with empty forum
