Question URL Issue
16 years 2 weeks ago #69505 by godweb
URL Issue was created by godweb
Hi, I updated my kunena 1.5.9 to 1.6, and to 1.6.1 (Joomla 1.5.22)
I use Artio 3.7.4 with the extension for kunena 2.0.13 (Default Joomla! router)
Alias in menu: forum-bla
My old url was like www.blabla.com/forum-bla/name-category/id-titlepost.html
New url are like www.blabla.com/component/kunena/name-category/id-titlepost.html
Any suggest?
16 years 2 weeks ago #69540 by haithun
Replied by haithun on topic Re: URL Issue
Just uninstall the extension for kunena and set the router to "Components router".
The following user(s) said Thank You: godweb
16 years 2 weeks ago #69578 by godweb
Replied by godweb on topic Re: URL Issue
Hi haithun, thanks. I have unistall the extension for kunena, but the URL are the same.
How I can set the router to "Components router"?
16 years 2 weeks ago #69589 by xillibit
Replied by xillibit on topic Re: URL Issue
I think he means, that you need to use the default sef system integrated into Joomla! instead of Artio sef.
16 years 2 weeks ago - 16 years 2 weeks ago #69594 by godweb
If so, now I'm using the default sef system integrated into Joomla! instead of Artio sef, but I have the same www.blabla.com/component/kunena/name-category/id-titlepost.html , wrong for my site.
With Kunena 1.5.9 I had www.blabla.com/forum-bla/name-category/id-titlepost.html
With Kunena 1.5.9 I was using Artio 3.7.4 with the extension for kunena 2.0.13 but set in Default Joomla! router)
I'm worried:sick:
Last edit: 16 years 2 weeks ago by godweb. Reason: Bad English ;)
16 years 2 weeks ago #69609 by haithun
@xillibit: No I mean that he should set the router for Kunena to the default router cause Artio JoomSEF is able to use different routers for different components.
@godweb Please reinstall JoomSEF and clear all the SEFed URLs and the cache. I just know this way to do it without querying the db manually but maybe xilli or any other developer know a better way. Then clear also the browser cache.
