Question [solved] URLs changed after upgrading
16 years 1 month ago - 16 years 1 month ago #66130 by Oscarfishlover
I was unaware that URLs were going to change after upgrading to 1.6. I did some testing and didn't think it was going to happen, but it has now I am down about 400 hits a day which is a little annoying. However, it's not the end of the world I suppose, I'm sure that the pages will eventually start showing on Google.
The #1 Oscar Fish website on the net
Joomla! 2.5.14
Kunena 3.0.2
Last edit: 16 years 1 month ago by fxstein.
16 years 1 month ago #66131 by fxstein
Can you give some examples?
Thx!
16 years 1 month ago - 16 years 1 month ago #66138 by Oscarfishlover
Okay, here's an example of the URL before upgrading (the URL that shows up on Google at the moment)
www.oscarfishlover.com/oscar-fish-advice...hy?limit=12&start=12
And now this is the new URL of the same page
www.oscarfishlover.com/forum/computer-ch...-many-on-line#118766
In Forum Configuration > SEO Settings, I have made search engine friendly URLs to "yes" and do not use IDs to "yes". Enable UTF-8 support is set to "know"
f
Joomla! 2.5.14
Kunena 3.0.2
Last edit: 16 years 1 month ago by Oscarfishlover.
16 years 1 month ago - 16 years 1 month ago #66141 by fxstein
Ok two things:
  1. You are in control of the URLs. The new install simply defaults to /forum but you can edit the menu alias of the Forum menu entry and put in"oscar-fish-advice-forum" to get /oscar-fish-advice-forum like you used before. I tried it manually and the old url will work. Also set Do Not use IDs to NO.
  2. Careful with those stats. If you want real users stats, I recommend you look at something like Google Analytics. Server stats can be misleading. Part ofthe numbers you are looking at it actually due to improvements of Kunena 1.6. For example kunena.com uses 1/2 of the GB transferred compared to a year ago while serving 50% more traffic. This is due to minified css and js in K1.6 as well as gzip page compression. So Data Volume going down is fully intended and a good thing. Same thing for hits - the css sprites will reduce the hits significantly. As for visits, I would change the URL alias and see how the next couple of days turn out. You also have to factor in any issues you had day 1 as well as going into the weekend.
Hope this helps!
16 years 1 month ago #66147 by fxstein
See here:
The following user(s) said Thank You: Oscarfishlover
16 years 1 month ago #66163 by Oscarfishlover
Yes, changing the alias has now matched the URLs so hopefully all those people who have been getting 404 error will now be able to visit the website with no problems. Thanks
Joomla! 2.5.14
Kunena 3.0.2
