Merged [Merged topic] An invalid post ID was requested
15 years 5 months ago #96153 by mwantedc
Thanks for so fast reply.
So since its on the posts that we have posted in some of our Forum sections are giving me an Error: An invalid post ID was requested. I know for sure the post is created and is on the forum, but since turning on SEO renames every url to .html Kunenan doesnt see it.
Thankk in advance for your help.
link to the forum: bmwsocialnetwork.com/index.php/forum/ind...-social-network.html
I turned the SEO and here is the Configuration Report:
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Disabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 50M
Joomla default template details : rt_meridian_j15 | author: RocketTheme | version: 1.5.0 | creationdate: 02/28/2009
Third-party components: Jomsocial 2.2.0
Plugins: System - Mootools Upgrade: Enabled | System - Mootools12: Disabled | Kunena Search 1.6.4 | Kunena Discuss 1.6.4 | My Kunena Forum Menu 1.6.4 | My Kunena Forum Posts 1.6.4 | Kunena Groups 1.6.4
Modules: Kunena Latest 1.6.4 | Kunena Login 1.6.4
15 years 5 months ago #96199 by sozzled
Your "forum is offline for maintenance". Can you allow us to see your forum, please.
Why do you have "legacy mode" enabled? Have you read the very important information about using legacy mode ?
You have not properly setup Joomla SEO. Please read Search Engine Optimisation (SEO) which shows you how to setup this Joomla feature. Thank you.
The following user(s) said Thank You: mwantedc
15 years 5 months ago #96376 by mwantedc
Thanks for your help, I followed information from wiki and configured my SEO, but I left the option mod_rewrite set to no and Add Suffix to URLs to yes. because it would brake most link on my site. I also renamed HTACCESS.TXT to HTACCESS
The forum works now, but strange didn't before.. here is the example of the one of our posts:
We use JomSocial as a community component for the website. We also have a plug in installed that shows My Kunena Forum Menu on the main page user profile or Community page. What leads me to the next problem those manu links giving me the following error:
Kunena: Unsupported output format htmlItemid53, please use only format=html or .html
we working on it now and hopefully will fix it.
Thank you for all your help! Kunena is the way!
15 years 5 months ago - 15 years 5 months ago #96388 by sozzled
Please read Search Engine Optimisaton (SEO) very carefully. It is not a long document to read, but it's easy to overlook some points that are made.
I'll summarise: Check only the first two radio buttons in the SEO settings and make sure that you have a file called .htaccess (it's not "htaccess" it's ". htaccess"; pronounced DOT-H-T-ACCESS)
Last edit: 15 years 5 months ago by sozzled.
The following user(s) said Thank You: camsarim
15 years 5 months ago #96594 by mwantedc
Thanks for all your help! Everything works fine!
14 years 7 months ago - 14 years 7 months ago #122415 by totalcampingireland
Hi my hosting company reciently updated their server, since then i am getting a An invalid post ID was requested. error for some of my forum categories. I have upgraded to 1.7.2 but am still getting the error message. Any help would be great
Last edit: 14 years 7 months ago by sozzled.
Time to create page: 0.285 seconds
