Merged [Merged topic] An invalid post ID was requested
16 years 5 months ago - 14 years 7 months ago #50668 by Requiem
After upgrade to 1.6
Last edit: 14 years 7 months ago by sozzled. Reason: Merge topics: change subject and topic icon
16 years 5 months ago #50680 by Matias
If you see this message, log in as administrator and Kunena will show you slightly different error message which asks you to enable debug mode (if admin gets the same error).
After you have enabled debug (either in Kunena or Joomla), you should see Joomla error page. Just copy its contents to this thread. :)
16 years 5 months ago #50731 by Requiem
JDatabaseMySQL::query: 1054 - Unknown column 'p.id' in 'field list' SQL=SELECT a.*, b.*, p.id AS poll_id, modified.name AS modified_name, modified.username AS modified_username FROM jos_kunena_messages AS a LEFT JOIN jos_kunena_messages_text AS b ON a.id=b.mesid LEFT JOIN jos_users AS modified ON a.modified_by = modified.id LEFT JOIN jos_kunena_polls AS p ON a.id=p.threadid WHERE a.id='3417' AND a.hold IN (0,1,2)
Call stack
# Function Location
1 JSite->dispatch() Z:\home\myjob\www\index.php:68
2 JComponentHelper->renderComponent() Z:\home\myjob\www\includes\application.php:124
3 require_once() Z:\home\myjob\www\libraries\joomla\application\component\helper.php:162
4 KunenaApp->__construct() Z:\home\myjob\www\components\com_kunena\kunena.php:698
5 CKunenaView->display() Z:\home\myjob\www\components\com_kunena\kunena.php:418
6 CKunenaView->getView() Z:\home\myjob\www\components\com_kunena\funcs\view.php:683
7 JDatabaseMySQL->loadObject() Z:\home\myjob\www\components\com_kunena\funcs\view.php:340
8 JDatabaseMySQL->query() Z:\home\myjob\www\libraries\joomla\database\database\mysql.php:435
9 JError->raiseError() Z:\home\myjob\www\libraries\joomla\database\database\mysql.php:231
10 JError->raise() Z:\home\myjob\www\libraries\joomla\error\error.php:171
11 JException->__construct() Z:\home\myjob\www\libraries\joomla\error\error.php:136
16 years 5 months ago - 16 years 5 months ago #50735 by Requiem
I fix this bug аnd now have another one
JDatabaseMySQL::query: 1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ') AND s.client_id = 0 GROUP BY s.userid' at line 1 SQL=SELECT s.userid, MAX(s.time) AS time FROM jos_session AS s WHERE s.userid IN (64,63,277,393,1041,1087,) AND s.client_id = 0 GROUP BY s.userid
Call stack
# Function Location
6 CKunenaTools->loadTemplate() Z:\home\myjob\www\components\com_kunena\funcs\view.php:693
7 require() Z:\home\myjob\www\components\com_kunena\class.kunena.php:917
8 CKunenaView->displayMessage() Z:\home\myjob\www\components\com_kunena\template\default\view\view.php:49
9 CKunenaViewMessage->display() Z:\home\myjob\www\components\com_kunena\funcs\view.php:634
10 CKunenaTools->loadTemplate() Z:\home\myjob\www\components\com_kunena\funcs\view.php:264
11 require() Z:\home\myjob\www\components\com_kunena\class.kunena.php:917
12 CKunenaViewMessage->displayProfile() Z:\home\myjob\www\components\com_kunena\template\default\view\message.php:92
13 CKunenaTools->loadTemplate() Z:\home\myjob\www\components\com_kunena\funcs\view.php:93
14 require() Z:\home\myjob\www\components\com_kunena\class.kunena.php:917
15 KunenaUser->isOnline() Z:\home\myjob\www\components\com_kunena\template\default\view\message.profilebox.php:56
16 JDatabaseMySQL->loadObjectList() Z:\home\myjob\www\administrator\components\com_kunena\libraries\user.php:264
17 JDatabaseMySQL->query() Z:\home\myjob\www\libraries\joomla\database\database\mysql.php:458
18 JError->raiseError() Z:\home\myjob\www\libraries\joomla\database\database\mysql.php:231
19 JError->raise() Z:\home\myjob\www\libraries\joomla\error\error.php:171
20 JException->__construct() Z:\home\myjob\www\libraries\joomla\error\error.php:136
Last edit: 16 years 5 months ago by Requiem.
16 years 5 months ago #50736 by xillibit
You said that you have fixed the bug, but how do you have done this ?
Do you migrate from k1.5 with hack poll ?
16 years 5 months ago - 16 years 5 months ago #50738 by Requiem
My fix
ALTER TABLE `jos_kunena_polls` CHANGE `pollid` `id` INT( 11 ) DEFAULT NULL AUTO_INCREMENT
Maybe it`s no correct, i don`t check other code
I migrate without hack poll.
UPD
I update 1.5.3 to 1.5.12 and migrate to 1.6
