Solved Kunena display component in link instead of forum [RESOLVED]
14 years 4 months ago #126685 by sozzled
I did advise. You don't use External URL. You use Alias Menu, as it says to do in Customised menus
14 years 4 months ago #126688 by nesh_bros
It would not work, I already try that before I report it on forum.
When I did that and click on link in menu I get domain.com/forum but when I click on every other link in menu its component/kunena..
14 years 4 months ago #126694 by nesh_bros
I used:
redirect /component/kunena/ www.domain.com/forum/
in htaccess file. Is this good solution?
Meny thanks!
14 years 4 months ago #126725 by nesh_bros
nesh_bros wrote: Hi,
I used:
Meny thanks!
No, its not. :) Visitors can not make posts with this solution.
14 years 4 months ago #126726 by sozzled
I probably would have said the same thing too. Have you tried using a non-customised .htaccess file (by renaming the original htaccess.txt)? I don't understand what the problem is here. Have you tried using the "trash-burn-build approach" to restore the Kunena menu (search for it on the forum)?
14 years 4 months ago - 14 years 4 months ago #126740 by nesh_bros
Thanks sozzled :)
This works! I just needed to restore the Kunena menu.
Thanks man :woohoo:
Last edit: 14 years 4 months ago by sozzled. Reason: Change topic icon to "solved"
