Solved Kunena display component in link instead of forum [RESOLVED]
13 years 10 months ago - 13 years 10 months ago #126607 by nesh_bros
Hi Kunena,
I installed Kunena, copy Kunena menu items in main-menu and name it forum.
domain.com/forum - when I click it forum opens, but when I click on any link inside forum I have:
domain.com/component/..
I need forum insted of component in link. I guess its something in menu settings but I try everything for the past 4 hours and nothing.
My config:
Joomla default template details : natabanu | author: Goran Neskovic | version: 2.0.0 | creationdate: 2012-May-25
Last edit: 13 years 10 months ago by nesh_bros.
13 years 10 months ago #126627 by Matias
Looks like your menu is slightly broken. I would remove the item you added and change forum2 in Kunena menu back to forum. Then find unpublished menu item in your default menu (called Forum) and publish it.
13 years 10 months ago #126655 by nesh_bros
Matias wrote: Looks like your menu is slightly broken. I would remove the item you added and change forum2 in Kunena menu back to forum. Then find unpublished menu item in your default menu (called Forum) and publish it.
I have published everything in kunena menu. In main menu I add new menu with external link: domain.com/forum and when I click it I get: domain.com/forum but when I click on any category or link I get component/kunena
Is there any code I can put in .htaccess to rewrite that?
Thanks!
13 years 10 months ago #126657 by sozzled
nesh_bros wrote: In main menu I add new menu with external link: domain.com/forum ...
We do not recommend using the menu item type of "External URL". By default, when you first install Kunena, the Kunena menu is added for you and a menu item is created (but left unpublished in case you want to move it elswhere). If you want to create your own custom menu then you should read Customised menus . I hope this helps.
13 years 10 months ago #126684 by nesh_bros
Hi sozzled,
I do external link because I cant use same alias twice, but like you said, I can move your menu and get rid of this menu item BUT I already try this, I still have unwanted "component/kunena" in link instead of just "forum".
Can you advise on this one?
Thanks.
Time to create page: 0.270 seconds
