Kunena 6.4.9 & Kunena 7.0.1 Released
The Kunena team has announce the arrival of Kunena 6.4.9 [K 6.4.9] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 6.4
The Kunena team has announce the arrival of Kunena 7.0.1 [K 7.0.1] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Solved [Resolved] Unable to delete posts
Except for the change you made to use the default Blue Eagle template, the configuration settings are identical in both cases!
So I will ask again to do what I asked you to do in msg #5.
(1) Use the Restore Default Settings facility: see How to reset Kunena confuguration back to default settings if you do not know how to do this
(2) Use the standard, default Kunena menu: remove all of your existing menu items that relate to the forum from your site, empty the menu trash and then re-create the standard Kunena menu; this is called the "trash-burn-build" technique. see How do I restore my Kunena menu?
In addition, you should also:
(3) Eliminate the possibility that there is a Javascript library conflict (for example, the accordion menu that you use requires jQuery which needs to be loaded in a very special way); see msg #1 of If you are having problems with Kunena, please read this first
(4) Enable Kunena debug mode to see if this may report additional information or error messages.
If these things do not work, we may need to look at your administrator website for ourselves (as long as that is agreeable to you) to see how you have set-up your website. Very puzzling!
- macintosh1988
And how to enable debug mode?
I don't think that this is any kind of JavaScript issue. Usually there are few possible reasons for this:
* URL isn't correct (what does the URL look alike?)
** SEF component issue
** Template issue
* A bug somewhere
You can enable debug either from Joomla or Kunena configuration (first tab)
- macintosh1988
When I'm trying to delete post in google chrome url look like:
site.ru/forum/forum_category/forum_topic...ed9bfc78846af749fd=1
then it changes to this:
site.ru/forum/forum_category/forum_topic/post.html?do=delete
And it lasts, while I won't stop it.
When I use firefox or opera browsers, nothing is happen.
This is my report after enabling "debug mode"
This message contains confidential informationhtaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 1000M
| ID | Name | Alias | Menutype | Link | ParentID |
| 42 | Форум | forum | kunenamenu | index.php?option=com_kunena&view=entrypage&defaultmenu=44 | 0 |
| 43 | Оглавление | index | kunenamenu | index.php?option=com_kunena&view=listcat | 42 |
| 44 | Последнее | recent | kunenamenu | index.php?option=com_kunena&view=latest | 42 |
| 45 | Новая тема | newtopic | kunenamenu | index.php?option=com_kunena&view=post&do=new | 42 |
| 46 | Без ответов | noreplies | kunenamenu | index.php?option=com_kunena&view=latest&do=noreplies | 42 |
| 47 | Мои темы | mylatest | kunenamenu | index.php?option=com_kunena&view=latest&do=mylatest | 42 |
| 48 | Профиль | profile | kunenamenu | index.php?option=com_kunena&view=profile | 42 |
| 27 | Форум | forum | mainmenu | index.php?option=com_kunena&view=entrypage&defaultmenu=42 | 0 |
Joomla default template details : ja_pollux | author: JoomlArt.com | version: 1.4 | creationdate: 2/13/08
board_offline 1 board_ofset 0.00 enablerss 0 enablepdf 0 threads_per_page 20 messages_per_page 15 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 0 template default showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 0 useredit 1 useredittime 0 useredittimegrace 1800 editmarkup 1 allowsubscriptions 1 subscriptionschecked 0 allowfavorites 1 maxsubject 200 maxsig 300 regonly 0 changename 1 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 1 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 avatarquality 65 avatarsize 512 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 350 allowfileupload 0 allowfileregupload 0 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2 filesize 120 showranking 1 rankimages 1 avatar_src fb fb_profile fb pm_component no userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 0 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory 0 showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 10 showpopsubjectstats 1 popsubjectcount 10 usernamechange 0 rules_infb 1 rules_cid 1 help_infb 1 help_cid 1 showspoilertag 1 showvideotag 1 showebaytag 1 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage recent default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 0 sefutf8 1 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 10 showpoppollstats 1 polltimebtvotes 01:00:00 pollnbvotesbyuser 100 pollresultsuserslist 0 maxpersotext 50 ordering_system mesid post_dateformat datetime_today post_dateformat_hover ago hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access communitybuilder integration_login communitybuilder integration_avatar communitybuilder integration_profile communitybuilder integration_private uddeim integration_activity communitybuilder boxghostmessage 0 userdeletetmessage 1 latestcategory_in 1 topicicons 1 onlineusers 1 debug 1 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 0 showpopthankyoustats 1 popthankscount 10 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 activity_limit 0 show_list_time 720 show_session_type 1 show_session_starttime 0 userlist_allowed 1 userlist_count_users 2 enable_threaded_layouts 0 category_subscriptions post topic_subscriptions every pubprofile 0 thankyou_max 10 email_recipient_count 0 email_recipient_privacy bcc email_visible_address captcha_post_limit 0
Third-party components: CommunityBuilder 1.7.1 | UddeIm 2.7
Please go to your Forum Configuration and use the button near the top right, indicated in the attached image:
You have two menu items with the same alias "forum"; you need to fix this.
- macintosh1988
| 52 | Форум | forum | kunenamenu | index.php?option=com_kunena&view=entrypage&defaultmenu=54 | 0 |
| 53 | Оглавление | index | kunenamenu | index.php?option=com_kunena&view=listcat | 52 |
| 54 | Последнее | recent | kunenamenu | index.php?option=com_kunena&view=latest | 52 |
| 55 | Новая тема | newtopic | kunenamenu | index.php?option=com_kunena&view=post&do=new | 52 |
| 56 | Без ответов | noreplies | kunenamenu | index.php?option=com_kunena&view=latest&do=noreplies | 52 |
| 57 | Мои темы | mylatest | kunenamenu | index.php?option=com_kunena&view=latest&do=mylatest | 52 |
| 58 | Профиль | profile | kunenamenu | index.php?option=com_kunena&view=profile | 52 |
| 59 | Правила | rules | kunenamenu | index.php?option=com_kunena&view=rules | 52 |
| 60 | Помощь | help | kunenamenu | index.php?option=com_kunena&view=help | 52 |
| 61 | Поиск | search | kunenamenu | index.php?option=com_kunena&view=search | 52 |
board_offline 0 board_ofset 0.00 enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 6 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 0 template default showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 1 maxsubject 50 maxsig 300 regonly 0 changename 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 150 allowfileupload 0 allowfileregupload 1 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2 filesize 120 showranking 1 rankimages 1 avatar_src fb fb_profile fb pm_component no userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 rules_infb 1 rules_cid 1 help_infb 1 help_cid 1 showspoilertag 1 showvideotag 1 showebaytag 1 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage recent default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 0 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access auto integration_login auto integration_avatar auto integration_profile auto integration_private auto integration_activity auto boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 activity_limit 0 show_list_time 720 show_session_type 0 show_session_starttime 0 userlist_allowed 0 userlist_count_users 1 enable_threaded_layouts 0 category_subscriptions post topic_subscriptions every pubprofile 1 thankyou_max 10 email_recipient_count 0 email_recipient_privacy bcc email_visible_address captcha_post_limit 0
