Solved [Resolved] Unable to delete posts
14 years 7 months ago - 14 years 7 months ago #122470 by macintosh1988
Hi there,
Kunena version is 1.7.2
I use different browsers.
Users, moderators, administrators aren't able to delete posts.
My setting allow them to do this.
But I can't understand, what's problem with it.
Last edit: 14 years 7 months ago by sozzled. Reason: Change topic icon
14 years 7 months ago #122511 by sozzled
Replied by sozzled on topic Re: Unable to delete posts.
G'day, macintosh1988, and welcome to Kunena.
macintosh1988 wrote: Users, moderators, administrators aren't able to delete posts.
Which setting is that? I suggest that you read What information should I include when I ask for help (including how to post my configuration report)? which may help you (and us) to know better why things are not working at your site.
14 years 7 months ago #122521 by macintosh1988
Ок. This is my Kunena report.
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 1000M
Joomla default template details : ja_pollux | author: JoomlArt.com | version: 1.4 | creationdate: 2/13/08
Kunena default template details : Example Template | author: Kunena Team | version: 1.7.2 | creationdate: 2012-01-31
Third-party components: CommunityBuilder 1.7.1 | UddeIm 2.7
14 years 7 months ago #122522 by macintosh1988
When user, moderators, administrators push button "delete", there's nothing happens.
14 years 7 months ago - 14 years 7 months ago #122526 by sozzled
Try resetting your Kunena configuration back to the original, default settings.
You could also try deleting all the Joomla menu items that refer to your forum and restore the default menu. The FAQ item How do I restore my Kunena menu? has all the details. :)
14 years 7 months ago - 14 years 7 months ago #122530 by macintosh1988
That's not helps.
I can reply, edit, moderate posts, but I can't delete.
Last edit: 14 years 7 months ago by macintosh1988.
Time to create page: 0.150 seconds
