Solved [Resolved] Unable to delete posts
14 years 7 months ago #122753 by Matias
Replied by Matias on topic Unable to delete posts.
What does Kunena say when you try to delete a post? I'm not sure if I saw that in the previous messages. I believe that you're trying to delete individual posts from a topic?
I don't think that this is any kind of JavaScript issue. Usually there are few possible reasons for this:
* URL isn't correct (what does the URL look alike?)
** SEF component issue
** Template issue
* A bug somewhere
You can enable debug either from Joomla or Kunena configuration (first tab)
The following user(s) said Thank You: macintosh1988
14 years 7 months ago - 14 years 7 months ago #122789 by macintosh1988
Yes, I'm trying to delete individual post from a topic. Even topic itself can't be deleted by a button "delete" (I have to open category, check topic, then to choose in listbox 'delete chosen").
When I'm trying to delete post in google chrome url look like:
site.ru/forum/forum_category/forum_topic...ed9bfc78846af749fd=1
then it changes to this:
site.ru/forum/forum_category/forum_topic/post.html?do=delete
And it lasts, while I won't stop it.
When I use firefox or opera browsers, nothing is happen.
This is my report after enabling "debug mode"
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 1000M
Joomla default template details : ja_pollux | author: JoomlArt.com | version: 1.4 | creationdate: 2/13/08
Third-party components: CommunityBuilder 1.7.1 | UddeIm 2.7
Last edit: 14 years 7 months ago by macintosh1988.
14 years 7 months ago - 14 years 7 months ago #122790 by sozzled
Replied by sozzled on topic Unable to delete posts.
I asked you, twice, to reset your forum configuration settings to the default values. You have not done that.
Please go to your Forum Configuration and use the button near the top right, indicated in the attached image:
You have two menu items with the same alias "forum"; you need to fix this.
Last edit: 14 years 7 months ago by sozzled.
14 years 7 months ago #122791 by macintosh1988
14 years 7 months ago #122792 by macintosh1988
Thnx, people. It works. Sorry for my stupidness :blush:
14 years 5 months ago #126201 by tyr
Replied by tyr on topic Unable to delete posts.
I am having the same problem and i dont knkoow why?
[/quote]
htaccess: Exists | PHP environment: Max execution time: 660 seconds | Max execution memory: 512M | Max file upload: 360M
Joomla default template details : ca_faith_j15 | author: CloudAccess.net | version: 2.0.0 | creationdate: May 10, 2011
Third-party components: CommunityBuilder 1.8 | UddeIm 2.8
Modules: Kunena Latest 1.6.4 | Kunena Stats 1.6.4 | Kunena Login 1.6.4 | Kunena Search 1.6.4
any thoughts?
Time to create page: 0.200 seconds
