The Kunena team has announce the arrival of Kunena 6.4.9 [K 6.4.9] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 6.4
The Kunena team has announce the arrival of Kunena 7.0.1 [K 7.0.1] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
I have no thoughts because you have edited your configuration report and stripped it of vital information that would assist us in solving your problem. Sorry.
Look at your configuration report. Update the out-of-date add-ons that you have installed. Look at the other recommendations we have given in this topic. If this is a case of I have the same problem ...
then please try the same solution. Thank you.
macintosh1988 wrote: Hi there,
Kunena version is 1.7.2
I use different browsers.
Users, moderators, administrators aren't able to delete posts.
My setting allow them to do this.
But I can't understand, what's problem with it.
Same problem! Reset settings and templates does not work. Any ideas?
Please post your un-edited configuration report, and read the rest of this topic, including sozzled's reply.
Please read the
FAQ. Only one question per topic. Search
before you ask a question.
