Question Problem with profile view and edit the forum Kunena
15 years 8 months ago - 15 years 8 months ago #90659 by sozzled
(1) Your missing BBcode toolbar, inability to view user profiles, use smileys, etc. are handled by the first message in If you are having problems with K 1.6, please read this first
(2) You are using J! 1.5.20 in legacy mode. Please
  • Upgrade to J! 1.5.22; and
  • Do not use legacy mode. Please read the very important advice about using legacy mode .
(3) Please read Search Engine Optimisation (SEO) to find out how to enable SEO on your site.
(4) If you need them, please upgrade Kunena Latest and Kunena Discuss (see Download page).
(5) You are not using the Kunena Login module (1.6.0-RC2); you should uninstall the Kunena Login module.
(5) Rumpel wrote:
At first reading in various forums, I read that you had to install JoomSocial or Community Builder. I decided to do with Community Builder and, no, still not function. If you can change the profile of CB but not that of K16. In fact the configuration tabs CB profile if they work.
Not true. You do not need to install JomSocial or Community Builder. However, if you do install this software, it's also your job to keep it updated.
Your main problems are caused by another Joomla extension, that you installed, that is not compatible with Mootools 1.2.4. For example, the Wibiya toolbar is incompatible with Mootools 1.2.4 - we know that - and I know that you have disabled it. There is another plugin or module (or maybe something installed by another component) that is incompatible with Mootools 1.2.4. All of this is mentioned in the topic If you are having problems with K 1.6, please read this first and in the K 1.6 Installation Guide .
The following user(s) said Thank You: Rumpel
15 years 8 months ago #90664 by Rumpel
At this time I get to study what I sent.
(Wibiya plug was off and I've deleted)
I will keep you with news.
Thanks for the support.
