Question Problem with profile view and edit the forum Kunena
Greetings.
I have a problem with the View and Edit Forum Profile Kunena 1.6
Since installing 1.6 Kunena tabs for details view (and edit) the profile does not show the information and editing options for the disabled seem to hover over them does not change the pointer and clicking nothing happens.
At first reading in various forums, I read that you had to install JoomSocial or Community Builder. I decided to do with Community Builder and, no, still not function. If you can change the profile of CB but not that of K16. In fact the configuration tabs CB profile if they work.
K16 configured for the profiles and avatars that appear to be of K16 and not CB, and although the avatars that are displayed are those of K16 is the problem of editing.
I tried also to change insole but not resolved. (Use rhuk_milkyway which is indicated that no such errors mark as read). FireBoard template also changed and there is no solution.
I could ask my users (over 2600 and growing) that now upload their data to CB, but is not the case because it interests me, by the time K16. Plus it's important because the user can manage their subscriptions, options, forum, messages, etc.
I read in the FireBoard forum was Plugin Mootools problem, having an older version or not upload at about K16 prieoridades scheme. Mootools checked out the latest (1.2.4) and that was over in the system on K16, K16 down to several places.
I also read that the symptoms of the problem "mootools vs K16" were:
Of which the highlighted in red are what I work the other if they work.How to Know if You Have a Mootools issue
If You Have a Conflict with Mootools Kunena, look for the Following Symptoms:
1. The performance of the forum on your website or Become unacceptably slow noticeably
2. The toolbar is Not Displayed BBcode and Does Not Work
3. You can not edit profiles
4. Smileys do not work [5]
5.The Kunena tabbed menu or not does not does work Appear
Then tell them that my problem is only the tabs in the editing and K16 profile view.
I walk up to you to find a solution either installation, hacking or modification in order to solve my problem.
Should I reinstall?
Would I return to version 1.5.2?
What do I do?
I hope your notes anxiously.
(I read a similar topic in this forum but did not work)
The configuration Report is this:
This message contains confidential informationhtaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 64M
board_title Foro de Ayuda board_offline 0 board_ofset 0 offline_message <h2>Los Foros se encuentran en mantenimiento.</h2>
<div>Regrese luego!</div>enablerss 1 enablepdf 0 threads_per_page 20 messages_per_page 10 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 1 disemoticons 0 template Argentrc showannouncement 1 avataroncat 1 catimagepath category_images/ showchildcaticon 1 annmodid 62, 64, 84 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 3600 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 0 allowfavorites 1 maxsubject 50 maxsig 300 regonly 0 changename 1 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 1 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 imageprocessor gd2 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 500 allowfileupload 0 allowfileregupload 1 filetypes pdf,zip,txt,doc,gz,tgz,rar filesize 4096 showranking 1 rankimages 1 avatar_src fb_profile pm_component userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 1 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory 0 showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 10 showpopsubjectstats 1 popsubjectcount 10 usernamechange 0 rules_infb 1 rules_cid 49 rules_link lasindias.net/indianopedia/Netiqueta help_infb 0 help_cid 1 help_link www.kunena.com/ showspoilertag 1 showvideotag 1 showebaytag 0 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 0 ebaylanguagecode es-es fbsessiontimeout 1800 highlightcode 1 rss_type topic rss_timelimit year rss_limit 1000 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 500 rss_old_titles 1 rss_cache 900 fbdefaultpage categories default_sort asc alphauserpointsnumchars 1 sef 1 sefcats 1 sefutf8 1 showimgforguest 1 showfileforguest 0 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 10 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 60 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access communitybuilder integration_login communitybuilder integration_avatar kunena integration_profile auto integration_private uddeim integration_activity communitybuilder boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 1 version_check 0 showthankyou 1 showpopthankyoustats 1 popthankscount 10 mod_see_deleted 1 bbcode_img_secure text listcat_show_moderators 1
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.3.1) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.3)
Plugins: System - Mootools12: Enabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.0-RC2) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed
Modules: Kunena Latest: Enabled (Version : 1.6.0-RC2) | Kunena Stats: Disabled or not installed | Kunena Login: Enabled (Version : 1.6.0-RC2)
Please update your Kunena versoin to 1.6.3, please take a look of this : docs.kunena.org/index.php/Common_causes_...29_issues_and_Kunena
To use porfile you don't need CB or Jomsocial, this two components can be used in complement of Kunena
xillibit wrote: Hello,
Thanks!!
I will now!
the update is like any other? :huh: :huh:
You need to prevent this mootools to be loadedRumpel wrote:
beginning to despair. :S
I update to K 1.6.3
Copyed the mootools.jc to /templates/rhuk_milkyway/src/mootools.js
paste this code in the template:
I moving up the system mootools pulugin and check: 1.2.4 (ok)
and part of the BBCode work (green arrow) like size text, spoiler, bolds, etc
but the images (red arrow) of smiles and insert images ([img]) not work, do not display y the message. :( [img]http://my.jetscreenshot.com/5563/20110328-c3nt-54kb.jpg[/img]
The function "Enlarge / Shrink" essage work god.
and sitill the tabs on profile are inactive (disabes) :S
do you need another information to help me?
Joomla default template details : rhuk_milkyway | author: Andy Miller | version: 1.0.2 | creationdate: 11/20/06
Kunena default template details : Argent(RC3 - stable) | author: Gonzaunit | version: 1.6.0 | creationdate: 2010-08-20
<div>Regrese luego!</div>enablerss 1 enablepdf 0 threads_per_page 20 messages_per_page 10 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 1 disemoticons 0 template Argentrc showannouncement 1 avataroncat 1 catimagepath category_images/ showchildcaticon 1 annmodid 62, 64, 84 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 3600 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 0 allowfavorites 1 maxsubject 50 maxsig 300 regonly 1 changename 1 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 1 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 avatarquality 65 avatarsize 2048 allowimageupload 1 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 500 allowfileupload 0 allowfileregupload 1 filetypes pdf,zip,txt,doc,gz,tgz,rar filesize 4096 showranking 1 rankimages 1 avatar_src fb_profile pm_component userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 1 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory 0 showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 10 showpopsubjectstats 1 popsubjectcount 10 usernamechange 0 rules_infb 1 rules_cid 49 help_infb 0 help_cid 1 showspoilertag 1 showvideotag 1 showebaytag 0 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 0 ebaylanguagecode es-es fbsessiontimeout 1800 highlightcode 1 rss_type topic rss_timelimit year rss_limit 1000 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 500 rss_old_titles 1 rss_cache 900 fbdefaultpage categories default_sort asc alphauserpointsnumchars 1 sef 1 sefcats 1 sefutf8 1 showimgforguest 1 showfileforguest 0 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 10 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 60 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access communitybuilder integration_login communitybuilder integration_avatar kunena integration_profile auto integration_private uddeim integration_activity communitybuilder boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 1 version_check 0 showthankyou 1 showpopthankyoustats 1 popthankscount 10 mod_see_deleted 1 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 activity_limit 0 show_list_time 720 show_session_type 0 show_session_starttime 0 userlist_allowed 0
Plugins: System - Mootools12: Enabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.0-RC2) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
