Question Problem with profile view and edit the forum Kunena
15 years 8 months ago #90595 by Rumpel
(text translate by google, sorry)
Greetings.
I have a problem with the View and Edit Forum Profile Kunena 1.6
Since installing 1.6 Kunena tabs for details view (and edit) the profile does not show the information and editing options for the disabled seem to hover over them does not change the pointer and clicking nothing happens.
At first reading in various forums, I read that you had to install JoomSocial or Community Builder. I decided to do with Community Builder and, no, still not function. If you can change the profile of CB but not that of K16. In fact the configuration tabs CB profile if they work.
K16 configured for the profiles and avatars that appear to be of K16 and not CB, and although the avatars that are displayed are those of K16 is the problem of editing.
I tried also to change insole but not resolved. (Use rhuk_milkyway which is indicated that no such errors mark as read). FireBoard template also changed and there is no solution.
I could ask my users (over 2600 and growing) that now upload their data to CB, but is not the case because it interests me, by the time K16. Plus it's important because the user can manage their subscriptions, options, forum, messages, etc.
I read in the FireBoard forum was Plugin Mootools problem, having an older version or not upload at about K16 prieoridades scheme. Mootools checked out the latest (1.2.4) and that was over in the system on K16, K16 down to several places.
I also read that the symptoms of the problem "mootools vs K16" were:
How to Know if You Have a Mootools issue
If You Have a Conflict with Mootools Kunena, look for the Following Symptoms:
1. The performance of the forum on your website or Become unacceptably slow noticeably
2. The toolbar is Not Displayed BBcode and Does Not Work
3. You can not edit profiles
4. Smileys do not work [5]
5.The Kunena tabbed menu or not does not does work Appear
Of which the highlighted in red are what I work the other if they work.
Then tell them that my problem is only the tabs in the editing and K16 profile view.
I walk up to you to find a solution either installation, hacking or modification in order to solve my problem.
Should I reinstall?
Would I return to version 1.5.2?
What do I do?
I hope your notes anxiously.
(I read a similar topic in this forum but did not work)
The configuration Report is this:
15 years 8 months ago #90607 by xillibit
Please update your Kunena versoin to 1.6.3, please take a look of this : docs.kunena.org/index.php/Common_causes_...29_issues_and_Kunena
To use porfile you don't need CB or Jomsocial, this two components can be used in complement of Kunena
15 years 8 months ago #90608 by Rumpel
Updated:
I try instal manualy the files and the line code in my template:
like here:
and here
but, the format toolbar does not appear
beginning to despair. :S :(
15 years 8 months ago #90611 by Rumpel
xillibit wrote: Hello,
Thanks!!
I will now!
the update is like any other? :huh: :huh:
15 years 8 months ago - 15 years 8 months ago #90615 by xillibit
Just install k1.6.3 the update is made automatically, but make a backup of kunena files, if you have done some changes like in templates...
You need to prevent this mootools to be loaded
Last edit: 15 years 8 months ago by xillibit.
15 years 8 months ago - 15 years 8 months ago #90654 by Rumpel
Hi:
I update to K 1.6.3
Copyed the mootools.jc to /templates/rhuk_milkyway/src/mootools.js
paste this code in the template:
<head> <script type="text/javascript" src="/templates/rhuk_milkyway/src/mootools.js"></script>
I moving up the system mootools pulugin and check: 1.2.4 (ok)
and part of the BBCode work (green arrow) like size text, spoiler, bolds, etc :)
but the images (red arrow) of smiles and insert images ([img]) not work, do not display y the message. :( [img]http://my.jetscreenshot.com/5563/20110328-c3nt-54kb.jpg[/img]
The function "Enlarge / Shrink" essage work god. :)
and sitill the tabs on profile are inactive (disabes) :S
do you need another information to help me? :( :(
Last edit: 15 years 8 months ago by Rumpel. Reason: format and update
Time to create page: 0.168 seconds
