14 years 4 months ago #129852 by chinhphong82
I install Kunena 1.7 in joomla 1.5, but BBcode error in New topics, see picture
(I have seach in forum but I can't download 2 file kunenaforum.js and kunenaforum.min.js.
and my folder "/public_html/components/com_kunena/template/default/js" haven't got any files kunenaforum.js and kunenaforum.min.js). Can you helf me?
14 years 4 months ago #129889 by sozzled
Please see msg #1 in this topic for advice on how to resolve these problems.
14 years 3 months ago - 14 years 3 months ago #130955 by falent
I have installed a great kunena forum but I don't have a kunena's BBcode toolbar. I see smiles but I can't use them. I don't see bbcode. How can I fix it? I installed System - Mootools Upgrade addon but It didn't help :(
In a attachment you can see situation on my kunena forum. I use Kunena 1.7.2
It is really strange but it is a fault from my template (krajeto.linuxpl.info/mat) from themza.com. In another template "smiles" and "bbcode help" work fine. Do you have any idea how can I fix it?
Last edit: 14 years 3 months ago by falent.
14 years 3 months ago #130971 by skipclarke
I had this same problem. I had installed CssJsCompress prior to upgrading from Fireboard to Kunena. It all happened in the span of a week, so I'm not sure if it had impacted FB as well. It was noticed after the Kunena upgrade, and disabling the module fixed it. Check to see if you have a CSS or JS compression module installed.
14 years 3 months ago #131000 by sozzled
*** Topics merged ***
The answers to these questions are given in msg #1 of this topic. We do not advise, recommend or provide advice relating to CSS/Javascript compression/obfuscation products. My personal advice is to disable such tools because they usually cause more problems than is worth using them.
14 years 3 months ago - 14 years 3 months ago #131272 by Annodompje
Hia there,
I've installed Kunena straight out of the box, hoping it would work.
First of all I couldnt edit my profile and after reading all the stuff about mootools I deleted a plugin and all that was fine. HOWEVER, now that the tabs and so-on are showing fine I cant actually click the edit button anymore. It has become plane text right next to the titel "Profile for Eef (Eef) Edit" all in text right next to eachother.
Im using Joomla 1.5.24, Kunena 1.7.2
Any chance anyone can help me out with this?
Thanks in advance ^.^
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 64M
Joomla default template details : rt_nebulae_j15 | author: RocketTheme, LLC | version: 1.5.2 | creationdate: November 11, 2011
Plugins: System - Mootools Upgrade: Enabled | System - Mootools12: Enabled
Last edit: 14 years 3 months ago by Annodompje.
Time to create page: 0.183 seconds
