14 years 8 months ago - 14 years 8 months ago #121151 by sozzled
G'day, blogizm, and welcome to Kunena.
The answer to most of your questions is to read msg #1 in this topic. That's what you need to do (whether you are a programmer or not). You have what what is known as a "Javascript library conflict". What this means is that you have chosen a Joomla site template (or possibly another extension) that uses software which does not properly work with Joomla.
We do not give answers in Ukrainian or Russian. Sorry.
Last edit: 14 years 8 months ago by sozzled.
14 years 8 months ago #121155 by blogizm
What do you advise me to do? Refer to the template developers?
14 years 8 months ago - 14 years 8 months ago #121158 by sozzled
blogizm: All the best advice, about what you need to do, is contained in the links in msg #1 of this topic.
14 years 7 months ago #121329 by arredoannunci
I have the same problem with my forum
no button to edit the profile works
how you solved it?
sorry for my English!
14 years 7 months ago #121359 by sozzled
G'day, arredoannunci, and welcome to Kunena.
If you have the same problem with your forum, then you should read msg #1 in this topic to find the answer.
14 years 7 months ago - 14 years 7 months ago #121375 by Isaiah53
Replied by Isaiah53 on topic Re: Post(Show) profile
I have just installed Kunena 1.7.2 on Joomla! 2.5.3 Stable. I and am also having a similar issue of not being able to "EDIT" the profile. The EDIT is there, but not able to click on and thus edit the profile.
Does anyone have a solution to this problem?
mimimike64 wrote: Bonjour,j'utilise joomla 1.5x et virtuemart 1.9 . kunena 1.72. Le bouton affiche le profil n'apparait pas. Il est donc impossible de modifier le profil d'un utilisateur ou d'ajouter des information. J'utilise un template Rokettheme. Merci pour la solution.
Hello, I use joomla 1.5x and virtuemart 1.9. Kunena 1.72. The button posts(shows) the profile does not appear. It is thus impossible to modify the profile of a user or to add information. I use a template Rokettheme. Thank you for the solution.
Last edit: 14 years 7 months ago by Isaiah53. Reason: forgot to add Joomla version
Time to create page: 0.171 seconds
