- Thank you received: 1
Merged [Merged topic] Rockettheme RokCandy plugin causes problems with Kunena
Update... Here is the fix provided by neutrino76 on the Rockettheme forums
/plugins/system/rokcandy_system.php find at line ~60
cascade wrote: I'm using Kunena 1.6.4 on Joomla 1.5.23 and am experiencing problems with text formatting. Text that are formatted in bold appear just fine (in bold) when saved first time. However, when I go back to the post and save it again, the text format disappears and the <b></b> or <strong></strong> tags appear. Sometimes, it happens to list format as well.
What can I do to prevent this from happening? Thank you for your help.
I found a workaround for this problem. It is related with rokcandy. The solution is to unpublish two of the example rules, the one for bold and the one for italics.
Hope it helps,
Sandra
