Question Embed images into post?
- soulkeeper
www.kunena.org/playground/main/75571-testing-image-insert#75571
You problem occurs with a website developed and running on your own PC, is that correct? I mean, we're not talking about an internet-based site at this time, right?
- soulkeeper
I also tried it from home, to make sure it wasn't this specific PC, and it is not. But like I mentioned, file upload/insert works on all other existing apps (cb, and joomla).
I could likely grab a different forum program, install it and test it as a secondary to see if it has a file attachment/insert issue as well.
It's very difficult to understand why you are having these issues without understanding your Joomla installation or seeing you K 1.6. configuration report . However, if you want to try a different forum application then there's probably no need to pursue this particular line of investigation until you have tried something else if that is what you want to do. Maybe you have not allowed image uploads? Maybe you have changed something in you forum configuration? Have you tried going back to the default settings?
- soulkeeper
I'm more than happy to reset it, but I'd prefer not to remove it and lose everything.
As for the config report, that's easy:
This message contains confidential informationhtaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 320M | Max file upload: 2M
Joomla default template details : grungyape_green | author: Franklin L. Petersen | version: 1.0 | creationdate: 2010-12-07
board_title Grungyape Forum board_offline 0 board_ofset 0.00 offline_message <h2>The Forum is currently offline for maintenance.</h2>
<div>Check back soon!</div>enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 6 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 0 template default showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 0 askemail 0 showemail 0 showuserstats 1 showkarma 0 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 1 maxsubject 50 maxsig 300 regonly 1 changename 0 pubwrite 0 floodprotection 5 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 150 allowfileupload 0 allowfileregupload 1 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2 filesize 120 showranking 0 rankimages 0 avatar_src fb fb_profile fb pm_component no userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_username 0 userlist_posts 1 userlist_karma 0 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 0 latestcategory 0 showstats 0 showwhoisonline 0 showgenstats 1 showpopuserstats 0 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 rules_infb 1 rules_cid 1 help_infb 1 help_cid 1 showspoilertag 1 showvideotag 1 showebaytag 1 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage recent default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 1 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 0 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access communitybuilder integration_login communitybuilder integration_avatar communitybuilder integration_profile communitybuilder integration_private communitybuilder integration_activity communitybuilder boxghostmessage 0 userdeletetmessage 1 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 0 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 activity_limit 0
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.3) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
Certainly, the fact that you're running on an IIS-based configuration, explains the format of the error message that you're receiving when your users attempt to insert message into Kunena, but it doesn't explain the cause.
Reverting to default settings is quite easy and it may be worth a try even though I think that there are other issues involved that will probably get in the way of solving the problem this way.
Go to Forum Configuration and click the Default icon on the top right corner of the page.
K 1.6 has not been tested on an IIS-based configuration (to my knowledge) and this is certainly outside my field of expertise. If I were in your shoes I would look deeper into the directory and/or file permissions issues. In Unix terms, folders and files should be owned by Apache with "755" for folders and "644" for files. I think this is where the answer lies. I don't have the specific answer for IIS, sorry.
