Question Embed images into post?
- soulkeeper
"K 1.6 has not been tested on an IIS-based configuration (to my knowledge)"
I only say this as I can use the Joomla 1.5 create new article, and then insert an image, and browse my PC, select and it uploads and appears just fine. I did not have to do anything special to make it work, and when Joomla installed, the folder was properly set as writable.
I also installed this afternoon jdownloader to test it out as a file manager. It installed without issue and once working, I was able to use the upload file feature without issue.
All of these files go to their respective folders without any action on my part. That said, as of right now, the only program not doing that, is Kunena. I can also browse to the folder that kunena is uploading to (under media) and confirm that not only are the folder permission the same as the other folders inside media, but they are able to accept files from extension without issues.
Again, I'm not saying its broke, you need to fix it, simply stating the situation I am facing.
But, because I have full access to the server its running on, I may bring up a new site, install Joomla and CB quick and grab the older 1.5.x version of kunena and see if that also has this issue.
On the other hand, why would the extended language support provided by mbstring alter this? Is it a requirement of 1.6
I'm using IIS6 as well and having the same problem attaching images. When I click submit on a message I receive the error
Before upgrading to Kunena 1.6.3, I was using Kunena 1.5.x and had no problems attaching images to posts. I also have JDownload installed and have no issues uploading files to it.JFile::copy: Cannot find or read file: 'C:\WINDOWS\Temp\php7F5.tmp'
Failed to upload file 'test.png': Could not move file into\Web Shares\Agwa\joomla\media/kunena/attachments\1329/test.png.
Shea
Legacy mode: Disabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Disabled | FTP layer: Disabled | htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : rhuk_milkyway | author: Andy Miller | version: 1.0.2 | creationdate: 11/20/06
board_title AGWA Support board_offline 0 board_ofset 0 offline_message <h2>The Forum is currently offline for maintenance.</h2>
<div>Check back soon!</div>enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 20 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 1 template default showannouncement 0 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 1 maxsubject 50 maxsig 0 regonly 0 changename 0 pubwrite 0 floodprotection 0 mailmod 1 mailadmin 1 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 0 allowavatargallery 0 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 1200 imagewidth 1600 imagesize 300 allowfileupload 0 allowfileregupload 1 filetypes zip filesize 2000 showranking 1 rankimages 1 avatar_src fb fb_profile pm_component userlist_rows 30 userlist_online 1 userlist_avatar 0 userlist_name 1 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory 0 showstats 0 showwhoisonline 1 showgenstats 0 showpopuserstats 0 popusercount 5 showpopsubjectstats 0 popsubjectcount 5 usernamechange 0 rules_infb 0 rules_cid 1 help_infb 0 help_cid 1 showspoilertag 0 showvideotag 0 showebaytag 0 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 0 autoembedebay 0 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage categories default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 0 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 0 imagemimetypes image/jpg,image/jpeg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access joomla integration_login joomla integration_avatar none integration_profile kunena integration_private none integration_activity none boxghostmessage 0 userdeletetmessage 1 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 activity_limit 0 show_list_time 720 show_session_type 0 show_session_starttime 0 userlist_allowed 0
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.4) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
Can you please post your full K 1.6 configuration report? You've removed a few things that might help us to understand better what's happening in your situation. Thanks.
One other point I would also make, please read Support for PC-hosted websites (e.g. WAMP, XAMPP) .
This message contains confidential informationhtaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Even so, this may or may not assist in your case. IIS uses a different permissions set to Apache. Again, you should enquire at forum.joomla.org to find out more about Joomla's recommendations in relation to directory and file security.
I may have misread your question and I apologise if I have. Kunena has, for the most part, been tested on Apache servers (which is also the situation in general as far as Joomla is concerned). No-one is emphatically saying that Joomla/Kunena is unsupported in IIS environments but we are saying that IIS has its own peculiarities, just like Ubuntu servers behave in slightly different ways to Apache, too.
I followed the recommendations at docs.joomla.org/IIS_and_Joomla for directory and file permissions. I'll try turning the SEO off to see if it makes a difference and I still need to read the link you posted in your previous message to see if there is anything that might help me there.
Could the forward slash vs backslash in the path it's trying to copy the file to make a difference?
Edit:It appears turning SEO off has no effect.
