Question My Forum is having problems loading
16 years 1 week ago - 16 years 1 week ago #70009 by jonny3010
thanks its working now but i want to have short url is thier any way
and i did not edit the .htaccess file just rename ill try new .htaccess form joomla.org
ok ive just done that got a new .htaccess and ive chnage settings back but same problems as be for so i changed back
Last edit: 16 years 1 week ago by jonny3010.
16 years 1 week ago #70060 by sozzled
jonny3010 wrote: thanks its working now ...
I'm sure that there are several other people who would love to know exactly what you did, what changes you made, to get your site working! Can you please provide some details of the changes you made? :dry:
16 years 1 week ago #70091 by jonny3010
well i when in to the global settings and change the Search Engine Friendly URLs to no as well as Use Apache mod_rewrite to no. kunena now works.
if any one know how to get it to work or if its a bug in the kunena component so we can get nice short urls:D
16 years 1 week ago - 16 years 1 week ago #70099 by sozzled
jonny3010 wrote: well i when in to the global settings and change the Search Engine Friendly URLs to no as well as Use Apache mod_rewrite to no. kunena now works.
Joomla SEO settings are fully explained in the guide in the Wiki: Search Engine Optimization (SEO)
This is standard Joomla. There is no bug in Kunena.
[strike]The point is that, in your case, you have overcome the "redirect loop" and that's where this discussion should stop. Thank you for your help. :)[/strike]
Late edit: I misunderstood the message. It appears that the user is unable to understand how to setup Joomla SEO without causing "redirect loop" problems.
Last edit: 16 years 1 week ago by sozzled.
16 years 1 week ago #70181 by jonny3010
ill give it a go but i read somewhere that a guy have the same problem so he when to 1.6.0 from 1.6.1. and it worked again so im thinking kuneuna team has change somthing?? to do with SEO
16 years 1 week ago - 16 years 1 week ago #70182 by sozzled
jonny3010 wrote: ill give it a go but i read somewhere that a guy have the same problem so he when to 1.6.0 from 1.6.1. and it worked again so im thinking kuneuna team has change somthing?? to do with SEO
Sometimes people write here "I read somewhere ..." and that's all we hear. I'm not doubting that you read something but, in response, I must ask you, "Where did you read this?" :dry: Yes, K 1.6.1 fixed many problems with K 1.6.1. You are already using K 1.6.1.
