Question My Forum is having problems loading
16 years 1 week ago - 16 years 1 week ago #69703 by jonny3010
My Forum is having problems loading its says
This web page has a redirect loop.
The web page at unlimitedgamers.tk/forum has resulted in too many redirects. Clearing your cookies for this site or allowing third-party cookies may fix the problem. If not, it is possibly a server configuration issue and not a problem with your computer.
kunena 1.6.1
Joomla 1.15.22
I hope you can help the config for the forum is defualt not chnaged
Last edit: 16 years 1 week ago by sozzled.
16 years 1 week ago #69707 by xillibit
Can-you post your report configuration settings ?
16 years 1 week ago #69708 by jonny3010
ok its
htaccess: Exists | PHP environment: Max execution time: 10 seconds | Max execution memory: 24M | Max file upload: 1500K
Joomla default template details : unlimitedgamers | author: | version: 1.0 | creationdate: 2010-11-06
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.2.3) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.1)
16 years 1 week ago #69867 by jonny3010
bump need help fast
16 years 1 week ago #69925 by sozzled
Are you using a customised .htaccess file? Are you using a third-party SEO product?
16 years 1 week ago #69955 by sozzled
Time to create page: 0.159 seconds
