Question size72 avatars does not exist while size200 avatar does
14 years 4 months ago #125659 by Matias
That's really odd as the images get created on the fly when they are requested by the api call. And there's nothing special in creating different sizes -- they are running the same code.
Can you provide the code you changed? (use code tag)
14 years 4 months ago #125755 by contender
/components/com_kunena/template/default/loginbox/login.php
<?php if ($login) : ?> <form action="<?php echo KunenaRoute::_(KUNENA_LIVEURLREL) ?>" method="post" name="login"> <div class="input"> <span> <?php echo JText::_('COM_KUNENA_A_USERNAME'); ?> <input type="text" name="<?php echo $login['field_username']; ?>" class="inputbox ks" alt="username" size="18" /> </span> <span> <?php echo JText::_('COM_KUNENA_PASS'); ?> <input type="password" name="<?php echo $login['field_password']; ?>" class="inputbox ks" size="18" alt="password" /></span> <span> <?php if(JPluginHelper::isEnabled('system', 'remember')) : ?> <?php echo JText::_('COM_KUNENA_LOGIN_REMEMBER_ME'); ?> <input type="checkbox" name="remember" alt="" value="yes" /> <?php endif; ?> <input type="submit" name="submit" class="kbutton" value="<?php echo JText::_('COM_KUNENA_PROFILEBOX_LOGIN'); ?>" /> <input type="hidden" name="option" value="<?php echo $login['option']; ?>" /> <?php if (!empty($login['view'])) : ?> <input type="hidden" name="view" value="<?php echo $login['view']; ?>" /> <?php endif; ?> <input type="hidden" name="task" value="<?php echo $login['task']; ?>" /> <input type="hidden" name="<?php echo $login['field_return']; ?>" value="<?php echo $return; ?>" /> <?php echo JHTML::_ ( 'form.token' ); ?> </span> </div> <div class="klink-block"> <span class="kprofilebox-pass"> <?php echo CKunenaLogin::getLostPasswordLink (); ?> </span> <span class="kprofilebox-user"> <?php echo CKunenaLogin::getLostUserLink ();?> </span> <?php $registration = CKunenaLogin::getRegisterLink (); if ($registration) : ?> <span class="kprofilebox-register"> <?php echo $registration ?> </span> <?php endif; ?> </div> </form> <?php endif; ?>
removed and replaced with a JFBConnect login easy-tag
14 years 4 months ago #125841 by Matias
Avatar isn't in that part of the code. :) Above code looks ok, but I suspect that there's a bug in avatar part.
14 years 4 months ago #126701 by contender
so what can be done to debug this avatar issue?
thank you :)
14 years 4 months ago #127000 by Matias
Skype me @ matias.griese -- this is too slow.
