Question size72 avatars does not exist while size200 avatar does
14 years 5 months ago #124920 by contender
exists:
longevityreview.com/media/kunena/avatars...0/users/avatar45.jpg
does not:
longevityreview.com/media/kunena/avatars...2/users/avatar45.jpg
what is going on here? Some members on my site have their size72 avatars while others do not.
How do I make sure Kunena creates a size72 avatar for the user?
14 years 5 months ago #124926 by sozzled
It depends on whether you have a GD graphics library installed. Your Kunena configuration settings will tell us more.
14 years 5 months ago - 14 years 5 months ago #124929 by contender
please tell me more about this GD graphics library. I don't have any 3rd party components installed on my Kunena
Last edit: 14 years 5 months ago by contender.
14 years 5 months ago #124930 by sozzled
If you post your configuration report, I will tell you if you have a problem with your GD library or not.
14 years 5 months ago #124956 by Matias
Smaller images are created on demand. So first you should check if they are generated when displayed.
If not, you probably have directory permission issues.
14 years 5 months ago #125098 by contender
so which directory should I look to, and which permissions should I set?
thanks
Time to create page: 0.158 seconds
