Merged xCloner bans all users from forum
15 years 2 months ago #105769 by Matias
I just figured it out: the value 0000-00-00 00:00:00 is wrong! It should be NULL for most users.
I suspect that something goes wrong when you clone the site. So please check BEFORE upgrading, that you do not have all users as banned.
The following user(s) said Thank You: manburg6
15 years 2 months ago #105824 by manburg6
You are right! I use sync functionality of phpmyadmin to replicate DB but the DATE field are converted from NULL to 000-00...
I open a ticket to my hosting provider and i will test upgrade to 1.7 starting from a correct db.
Thanks you,
Mario
15 years 2 months ago - 15 years 2 months ago #105826 by manburg6
Ok... i've exported and imported db and now the user are ok.
It's already open the issues about tag in forum descriprion.
In kunena 1.6.4 if I use tag like , etc... it works and i can have an icon on the side of forum description.
In kunena 1.7 something goes wrong because the forum description is broken.
Something change in tab trascoding?
I which way I can add an icon on the side of test in forum description?
Actually the code that works is the following:
[img
Repellenti, dopopuntura, lenitivi, insomma tutto ciò che è utile per proteggere e curare i più piccoli. Le nostre esperienze e i nostri consigli per prevenire ma molto più spesso curare le punture da insetto.
Thanks,
Mario
Last edit: 15 years 2 months ago by manburg6.
15 years 2 months ago #105894 by Matias
What is the BBCode for that? Because of I fixed a bug for the images...
15 years 2 months ago - 15 years 2 months ago #105918 by manburg6
Sorry... I made a mistake.
I call it BBcode but I mean html code into square bracket [].
15 years 2 months ago #105928 by Matias
No, that was not what I meant. I would like to see your broken category description "source code" as you've written it. Please put it into code tag.
You cannot add any html in K1.6..
